Back-Up Sensor
Back-Up Sensor
My sensor has been acting up for 6 months, but of course the dealer could never find anything. Now, when I put it in R it goes off when nothing is there. I have cleaned the bumper many times. nothing.
Can it be fixed or reset or shut off?
Thanks,
Drew
Thanks,
Drew
AudiWorld Expert
You can adjust the volume of the backup sensors...
My guess, you can lower it to the lowest volume setting, and maybe only the dog across the street will hear it.
Mine has been acting up as well. Worked just fine yesterday (parallel parked couple of times, and it REALLY helped), but this AM, constant tone with nothing there.
AudiWorld Expert
The volume settings are via the VAG COM cable...
if you do not have access to a VAG COM, check Stoney's Links under VAG COM for a list of folks near you.
Hmm
I faced a similar problem on a 2002 A6 and it told me exactly which sensor to replace. I guess it's not 100% certain there will be a fault code, but it's worth checking.
you've got a bad wire on one of the sensors. Happened to me when I was....
rear ended. Tried to re-use some of the sensors but was getting the constant tone in reverse. Found one of the sensors had the insulation coming off of one of the wires. Replaced it and it was good as new.
