blinker switch doesn't work
Old Jun 29, 2005 | 07:27 PM
Audi_RKT....(Bedros)'s Avatar
Default blinker switch doesn't work
the hazard switch works fine, but the turn signal switch doesn't work.
anyone knows if there's actually two relays, one for hazard and one for turn signals?
if so, which one is for the turn signals and what is the part number?
thanks
Old Jun 29, 2005 | 08:28 PM
Egil A64.2s - S6's Avatar
Probably the actuator swich in the steering wheel assembly.
Old Jun 29, 2005 | 08:40 PM
wayred4.2's Avatar
Default Re: blinker switch doesn't work
very common, there are two in the blinker assembly, just installed a replacement (after same symptoms) one TODAY. See Stoney's links for the details DIY write up. By switch online for <$25
Old Jun 30, 2005 | 03:34 AM
Boston Driver's Avatar
AudiWorld Expert
Default The relay for the hazard and turn signals are combined...
check out this post, which shows the internal components of the hazard/signal relay. It also gives you the aprt numbers, and how to replace it. For an allroad, but the same thing as the A6.
Try this frist, not a very expensive part at all, and very easy to swap out.<ul><li><a href="https://forums.audiworld.com/allroad/msgs/91515.phtml">Hazard/blinker relay</a></li></ul>
Old Jun 30, 2005 | 06:26 PM
ESN's Avatar
ESN
Elder Member
my money's on the fluid
Old Jul 1, 2005 | 08:23 AM
thanks guys for the help; I'll order one and replace it.
Old Nov 3, 2005 | 09:25 PM
lunamollie's Avatar
Default Re: The relay for the hazard and turn signals are combined...
Just had the same problem with my A6. Blinker started to flash irregularly and then quit altogether. Three months after the warranty ended. Figures. Anyway, popped off dash bracket, pulled the hazard light switch out, and replaced it. Took 20 minutes and cost $32 at the Audi dealership. Works great.
StevenH
Aug 5, 2022 10:36 AM
chapman62083
Jan 25, 2012 10:51 AM
jeffhikes
Audi 100 / A6 (C4 Platform)
Aug 13, 2010 01:41 PM
will_it_dude
Mar 6, 2006 09:11 AM
A4_b4_996
Dec 20, 2004 07:22 AM
