engine block drain plug
Heck, The radiator on my car doesn't even have a coolant drain plug. Must always pull the lower hose to drain the coolant.
as far as the 4.2 I have only have mine for a month and a half and haven't looked for it yet. But it is up on jack stands still, If I have time while under it wrapping up the trans fluid etc this evening I will see if I can spot the drain plug.
actually like usual google really is your friend
in not even 5 minutes I found this... http://www.cpp.edu/~bvnorum/ebahn/c5...drain_fill.pdf I searched "audi c5 4.2 coolant drain plug" and it was the 1st result.
But mine is a 2.7T, so maybe others are different.
https://www.audiworld.com/forums/s4-.../#post14480582
