front signal problems
#11
okay your right it comes unconnected with the littlest bump....any ideas on how to proceed? should I take off the head light assembly and clean the contacts or look at buying a new connector? what are your thoughts?
#12
What connector are you referring? Perhaps a picture.
#13
Suggestions
Really, when snugly and correctly fitted, the connection should be solid, so as the next step I'd recommend diligently making sure the plugs are connected as they should be.
Then again, if someone has broken off the retaining clip or tab (maybe whoever did the engine work?) then yes, then the connector would be loose due to damage, and then you'd have to install a replacement, either at the end of the wire (the way Audi did it) or by cutting the wire near the connector and splicing in a pigtail. The latter I would do with, ideally, soldering and heat-shrink connectors, to keep things reasonably reliable.
The Xenon high-output headlamps were an optional extra, so unless the connectors were identical for these vs. the regular headlamps (I hope that's not so but let's not rule that out), there could potentially be at least two different styles of connectors ...
Is this helpful?
Kevin G Mason
08-09-2017 08:13 AM
audi2.7audi
11-12-2004 04:09 PM
neis
12-28-2002 09:15 AM
