HELP! replaced dead battery and now my car can't move!
Car is out of commission. Tried to replace the battery and seems like my ECU has gone bezerk. My car dies immediately after start-up, I can keep it steady up to 4k rpm but once I let go of the gas the car dies. it also sputters like stuttering John misfiring and hee haw!
I just wanted to replace my dead battery! I think I need to VAG to try and reset ECU. I tried to leave the key in "accessory" position for a few minutes after reconnecting and before starting but no such luck to reset!
Please help, it's stuck over 50 miles from my regular mechanic and towing is going to kill me!
Email or post any help thanks!
Make sure the negative cable is firmly attached at each end
Are you sure it was the battery that was "the problem"?
https://forums.audiworld.com/9080/msgs/97292.phtml
https://forums.audiworld.com/a6/msgs/100164.phtml
https://forums.audiworld.com/s4/msgs/490726.phtml
https://forums.audiworld.com/a4/msgs/1737893.phtml
https://forums.audiworld.com/a4/msgs/793314.phtml
https://forums.audiworld.com/a4/msgs/2144719.phtml
https://forums.audiworld.com/a4/msgs/1697774.phtml
Codes if you have a VAG COM:
https://forums.audiworld.com/a6/msgs/375649.phtml
DerAudiA4
04-11-2009 08:20 PM
LIRS6
10-31-2008 06:46 PM
dansworld
02-25-2007 06:35 PM
ch11
02-09-2003 02:29 PM
MichaelTM
12-22-2002 01:51 PM
