High beam and right blinker problem
Hello all, I'm having problem with my high beam and right blinker, both of them doesn't work. Does any body have an answer to resolve this issues. Thanks in advance!!!
AudiWorld Expert
If I had to guess, you need to replace the signal stalk which controls blinkers and high beams
It is possible to DIY, but you need to take off the steering wheel (and airbag) and open up the steering column to get at the signal stalk.
Dealer will likely charge 2 hours of labor, plus the part for a total of $300 or so. The only special tool you need is a M12 triple-square bit to remove the steering wheel bolt. It can be purchased from AutoZone for under $15 for a set of four different sizes, including the one needed.
Check out my writeup below for additional detail...<ul><li><a href="https://www.audiworld.com/tech/elec162.shtml">A6 signal stalk replacement</a></li></ul>
