I need some opinions on the K&N Performance Air Filter.
Old 01-01-2009, 07:11 PM
Audifan1's Avatar
Default I need some opinions on the K&N Performance Air Filter.
Is it worth it to pay double the price for performace air filter? I understand that they are usable and such, but is it worth the money or should I just stick with the basic air filter?
Also, Mobil 1 OW40 Synthetic good choice for a 2000 A6 2.7t?
Old 01-01-2009, 07:16 PM
paulroad's Avatar
Default use the regular.
I had a K+N and its not worth it to clean and oil it.
JimmyC83's Avatar
Default the Motor oil is fine
The K&N Lube oil in the air filter is not.
it can get into the system (MAF) and "kill" it
Old 01-02-2009, 01:39 AM
Ace Ventura
bac2h's Avatar
Oil = good...........air filter = waste of money
Old 01-02-2009, 03:11 AM
Edd W's Avatar
Default It is a physical fact that you cannot filter air without introducing some form.....
of restriction in flow. Therefore if you have a filter which flows more air for the same given surface area, it will not filter as well - your choice.
This is ignoring the fact or fiction behind the possible problems caused to the MAF sensor which is not designed to be dombarded with micro-droplets of oil from time to time - it is designed to work in clean, dry air, which has passed through a paper filter - again, your choice.
Old 01-02-2009, 03:57 AM
donp's Avatar
Default I ran tests with and w/o K&N. No change in measured airflow a chipped 2.7t.
The airbox/air filter is not a point of restriction on the 2.7t. Save your money... just use a regular filter.
M1. Good choice.
Old 01-02-2009, 04:04 AM
Tech Guru
4Driver4's Avatar
Default I doubt anyone here would encourage you to buy anything other than paper.
STFA for MAF.
Old 01-02-2009, 04:17 AM
TwinTurboTerror's Avatar
They tend to screw up the MAF sensors because of the oil on the filter.
Old 01-02-2009, 04:50 AM
Fear the Miata!
Press's Avatar
skip....the oil is fine, been using it in the big girl forever
Old 01-02-2009, 06:37 AM
AudiWorld Expert
2.7tDallas's Avatar
shhhhh - don't confuse people with actual measurable facts!
Quick Reply: I need some opinions on the K&N Performance Air Filter.
