Im losing hydraulic fluid...I've filled the reservoir twice in 2 months...more
Where is the fluid going?? I don't see it on the ground..I doubt this very much, but is it all possible that it is getting into the engine or transmission??
I haven't able to look at the undercarriage and I don't see anything in the engine compartment that would indicate a leak.....
If it's the power steering fluid..
You probably have a leak in the p/s rack. You typically won't find it on the ground, because it leaks out while you're driving. Had the same problem with my '87 5000Q; was replaced under warranty.
Yikes?
My PS fluid is low - when it gets really cold, I see air being drawn into the circuit at the bottom of the reservoir in a little vortex, and I can hear a buzzing sound coming from the PS pump for about 5 minutes. I'll get this topped up today, but should I be worried about any damage?
greenaudi100german
03-01-2008 05:26 PM
gio
06-14-2007 07:57 AM
DM-S4
08-27-2006 07:41 PM
azndrunk74
03-03-2004 08:08 AM
