Immobilizer Key Code - Dealer Only????
2001 2.7T build date 11/2000, just purchased, only had one key with it.
Just want to confirm that I absolutely have to go to the dealer to get the immobilizer coded for a new key. I searched the forum and seems like I have immobilizer 2 with 4 digit code.
Purchased a key from autotransponder.com, they made the blade from a picture, works perfect. I was able to program the remote functions but of course immobilizer won't let it keep car running.
How can the immobilizer be disabled, any write up?
Thanks
Thanks
If you go to nefmoto.com you'll find ways of disabling the immobilizer. You'll need to learn a great deal about programming your own ECU with the nefmoto software, but at the end you'll come out a better man.
If you don't have the time or energy to invest into this, a trip to the dealer is your only option (or possibly taking the ECU out, shipping to someone who knows nefmoto and having them disable the immobilizer, but this is a lengthy process).
Just be sure to take ALL your keys to the dealer, including the service key. Whichever key he does not code will not work, even if that key worked before.
Some Indy Locksmiths can get the code
Thanks
Thanks
The dealer retrieves the SKC, but isn't actually able to "see" it to give it to you, but they can code the key for you. For the first couple of years on your 01, they could download the SKC and the date (it changes daily) to use with VCDS. I think that some locksmiths have a software package that lets them capture the SKC and date for you, as well as code the key to your car. I looked at the nefmoto stuff and it was pretty complex, but I do agree that I would be a better person if I learned it!
Good luck either way.
Or read out your ECU dump, and we can shut down your immo altogether.
Cluster and ECU dump
I have immo disabled now but like the idea of just coding new keys with the skc because then you won't get the annoying blinking light.
If you do a search for a member call ddilenger on nefmoto, he is the guy that really knows a great deal about this stuff. I'm in the process of playing with it now.
I am in similar situation with a key. My cluster was replaced during warranty (due to fading display!) and at that time, couldn't find one key. Dealer coded 1 key along with the valet key. Later on, I found the second one and can't use it. It's always in the back of my mind about what I'd have to do if I lose the main key. of course, the valet key will come to rescue but still...
But, I don't want to disable immobilizer. Is there a way to code it? OR, disable immobilizer > code > enable immobilizer?? (of course, saying that right now without much insight into the actual programming implications)
A8AWD
08-26-2007 08:42 PM
aurum
05-14-2007 12:04 AM
case allroad
14
02-24-2004 10:27 AM
KMU
04-10-2003 06:59 AM
