login needed for brake coding?
I see in the ross tech wiki that I need a login to code the brakes. What is this login? Would it be that same SKC for programming immo?
Since I installed a different ecu here is what I am getting for the brakes section:
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 06397
Shop #: WSC 02335
VCID: 2649E841C2FC2C9
2 Faults Found:
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
Coding: 06397
Shop #: WSC 02335
2 Faults Found:
I worked through the video and wrote down what I think is correct for my car. My login is 07597 and my coding is 06397. Oddly enough, the coding is already set to that but I am still getting errors. Before the fiasco with APR and the original ecu they destroyed, all my modules were working flawlessly and I had absolutely no faults. Keep in mind, I have an A6 quattro and I have an A6 Allroad file running the car. 551 AA compared to a 551 R. Here's what still happening:
Coding: 06397
Shop #: WSC 02335
2 Faults Found:
Coding: 06397
Shop #: WSC 02335
2 Faults Found:
carl viking
36
04-27-2020 01:17 PM
N'Syncro
33
02-16-2020 03:12 PM
stormchaser1967
09-02-2015 09:26 AM
