muffler tip cutouts for < 2002 folks ?
Anyone have suggestions on the best route to follow here? I'm not sure my hand is steady enough to modify my existing valence with a grinder/dremel and I don't like the look of the angled-down tips. This will be for a Milltek 3" catback + downpipes install on my '01 2.7T.
Cheers,
Cheers,
AudiWorld Expert
They guy that did it for me...
installed the exposed exhaust tips first (after dropping the exhaust down). Then raised the exhaust up to the valence, marked where he wanted to cut, and then went at it. Did this about 4-5 times, each time enlarging the hole just a bit more to make sure the spacing was even.
Just make sure that whoever does the cutouts for you starts small, because you can always make the opening bigger, but you cannot make it smaller once it is cut.
Also, make sure that the spacing from the edge of the rear valance to the opening is even. You don't want it to look uncentered.
Best of luck!
Best of luck!
Did mine while the car was on the lift
I used a Sharpie marker to outline the areas to be cut by eye, then I cut them out with a dremel tool. Took like 20 mins. I put door edge moulding where I cut and the cut-outs look fantastic!
dremel it out (smaller than you want) then use a sanding tip to get the shape perfect
...and if youre still neverious and youre around chicago im sure you could talk cl into doing it
AudiWorld Expert
fionnehs and Jmacs2.7T (out on paternity leave)....
When Jmacs2.7T had his valence cut, the outermost sensors had to be moved over just a little bit because they were occupying the space needed for the cutout. Fionnehs also did this mod, and insulated the wires.
A6Fanboi
18
05-22-2006 06:49 AM
audi 6 times
08-06-2004 08:11 AM
a_o_smith
11
08-02-2004 01:04 PM
Josh S4
05-12-2003 07:42 AM
