No power coming from the wire that goes to the SAI pump? 2001 Audi A6 2.7t
#11
Another issue I found is that the pipe from the driver side combi valve is broken...Below is the picture...
Now the question is, do I have to replace the whole pipe or can I just replace the piece between the combi valve and the metal pipe??? what is this pipe called??? part number or name?? thanks...
#13
Use the vag-com to turn it on and then check the voltage. I am not sure if ALWAYS comes on during the first 10 seconds, and I have noticed it coming on after driving for about 2 minutes and then coming to a stop, when the engine is not up to temp yet....the vag-com would be the most reliable way to check.
#14
Now I'm going to clear the code, and see if it stays off for good. thanks guys. will keep you updated.
#15
Before replacing secondary air pump on 98 Audi A6 Quattro, I'm checking a few things. I replaced the pump relay and tried to replace the pump fuse in the ECU relay panel, but didn't see a place for the 40 amp fuse. Do all engines require this fuse? Maybe I'm missing something. Only 80K miles and have owned for 10yrs and am convinced it's not the pump. I'm thinking it's a hose or the power supply. Any help would be appreciated, thanks!
#16
If you are certain that it is not the pump, verify that by removing the electrical connector to the pump and give it 12 vdc on one connector and ground on the other. The pump should power up and make that dentist drill sound.
The 40 amp fuse for the SAI pump is located in the box that holds the ECU, under the cowl cover, at the base of the windshield, driver side.
#17
Thanks georgeb944,
So there is no 40 amp fuse in the panel. I replaced the pump relay (J299) (plugs were pretty burnt at the bases) but there wasn't a pump fuse (S130) to be replaced. I'm wondering if this amp is necessary or possibly taken out and not replaced a while back when I had some work done.
#18
Yes I was checking during the first 10 sec of starting the car.
Surprisingly, the pump kicked in couple of times this morning, but after 2-3 times it didn't.
Another test I did was that I removed the relay, and completed the circuit with a piece of wire, and the pump started. Then I checked the voltage on the two pins where the relay sits on, and before starting the car, the voltage reading was 3.41, and after starting the car, the voltage reading was 9.98-10.05...A6 / S6 (C5 Platform) Discussion
Now the question is, what is the proper voltage that should be coming through the relay harness/connector (where the relay sits on)...???
Also the voltage doesn't drop...I thought the voltage should drop after the first 10 seconds, discharging the relay and breaking the circuit. Is that how this relay supposed to work???
If anyone has a multimeter, can you please check the voltage coming out of the SAI relay connecter??? before and after starting the car...thanks...
#19
No 40amp in sai
Does anyone know why there wouldn't be a place for a 40amp in the ecu sai relay panel? Would it be someplace else? Every picture or diagram has a place for it. Any help would be appreciated
#20
No 40amp in sai
