STFA and could not find a similar problem/answer regarding rear drivers side window
Today I noticed that my rear drivers side window will not roll down. I tried the master switch on my drivers door - didn't go down. Tried to switch on the rear drivers side door - didn't go down. Tried using my key, putting it into the driver door lock and turning it all the way forward, all the windows went down - except the rear drivers side door.
Thoughts?
TIA
Thoughts?
TIA
If it works when you hold down the master switch lock & window buttons...
Then you need to replace the master switch. Very common problem.
Search for "window master switch".
Reifle
01-02-2012 07:17 AM
TTS_4_to_A6
09-21-2009 02:45 PM
postalChange
08-16-2005 10:26 AM
