Tie rod end replacement
Hi...
I've tried to replace the tie rod end today but I couldn't get the tie rod end off the tie rod. I've searched the forums and found that lots of people had the same problem - they all ended up getting the TRE replaced by the dealer or an indy.
Does any one have a solution to remove the tie rod end from the tie rod? I've tried soaking the tie rod end threads in penetrating oil, but it still wouldn't budge.
Thanks in advance.
Thanks in advance.
True, even the Bentley says "If boot is damaged, replace"..and that's w/out applying heat.
Sound like the way to go is to use a quality penetrating oil (PB Blaster, in my tool chest) and maybe rap on it with a brass hammer to help crack it loose. I need to do mine this week or next & get the alignment done so I'll post photos and whatnot.
The reason Im going to the dealer is because of the alignment afterwards.
When I got my coilovers installed last weekend, the tech said my tie end rod is frozen too and heating it would melt it. So im going to have the dealer replace both of them, either today or tomorrow as a matter of fact. The reason for me is because the dealer knows the right way to align our quattro equipped cars.
I've got a nice performance tire shop with a well-experienced alignment tech who really knows Audis.
$100. Well worth it. And the last time or two, they knocked $10 off, as I've been a pretty good referral source.
egustaps
09-17-2008 07:25 PM
audi2.7audi
10-07-2005 04:19 AM
ahaiceman
09-08-2005 03:43 AM
