Tranny Swap Question
Old 07-22-2009, 03:23 AM
JerzyBoy973's Avatar
Default Tranny Swap Question
Hey guys, I've been wondering if a 2.7 6-speed gearbox would swap into a 5-speed 2.8. Just curious.
Old 07-22-2009, 04:02 PM
any audi techs out there?
Old 07-22-2009, 05:00 PM
Tech Guru
4Driver4's Avatar
I don't recall anyone doing this swap.
The six speed should bolt right in. The driveshafts are probably the same, the shift linkage might need to be changed.
I'm not sure about the final drive ratios. That would be the main thing to check.
Old 07-23-2009, 09:52 AM
Cool. I've been thinking about it lately during highway rides where I wished I had another gear to get my RPMs lower and save some gas.
Old 07-23-2009, 10:00 AM
Tech Guru
4Driver4's Avatar
That's why you need to check the ratios. In many cases, Audi just squishes the gears together and the five speed and six speed have the same top gear.
In the Miata, I considered going to a six speed, until I found out that the rpm's would actually be higher on the highway with the six speed.
Old 07-23-2009, 10:45 AM
tecra's Avatar
Default 6-speed swap into 2.8?
Sound like a lot of work. IMHO doing this in a 4.2 give you a lot more reward for similar amount of work. And I think the fuel consumption will be similar to that of 2.8. Saw a 4.2 6-speed on Fourtitude, sweet...
Old 07-23-2009, 10:57 AM
Tech Guru
4Driver4's Avatar
It's a lot more work on the four-two.
He's swapping stick to stick on the two-eight; the four-two requires tons of conversion (pedals, linkage, ecu, etc)
Old 07-23-2009, 11:24 AM
I'll look into it. Thx for the help as always man.
I don't own a 4.2
Old 07-23-2009, 01:12 PM
2.7Lturbo's Avatar
drive ratios are different, 6th is a LOT taller, feels like it anyways, dont know the exact ratios
Old 07-23-2009, 01:26 PM
advancedautomotion's Avatar
Yup you can use a 6 speed and parts from a 2.7tt.
You'll need:
axles
rear diff
prop shaft
trans
possibly a flywheel...
You can also look at using alternative gear or a european trans from a TDI if you want numerically lower gears or earlier 01A transmissions if you want numerically higher gears it's all a matter of what your goals are.
Quick Reply: Tranny Swap Question
