Trunk Does Lock
Old Oct 27, 2012 | 06:44 AM
CanadaA62001's Avatar
Default Trunk Does Lock
By mistake the other day I tried to open my trunk while the car was locked....and surprising enough it opened. In some cases - the alarm would go off - but in all cases it would open. My fear ...how long has this been going on? About a month ago I had the left front door painted. During the removal of the door could they have damaged the trunk locking mechanism?
Please help.
My next step would be to go to the dealer but I would rather not pay $250 for them to just investigate.
Any ideas.
jim
Old Oct 27, 2012 | 06:53 AM
Default Trunk can lock manually
Just as an additional note the trunk will lock - using the key and inserting and manually turning.
Not sure if this helps diagnosing. it does help me ....at least I know I can lock the car.
jim
Old Oct 27, 2012 | 06:51 PM
Blackfunk's Avatar
Top Answer: 1
I noticed I had this same issue recently but it turns out the based on the position of the lock when using the key it actually does lock.
If memory serves turning the key counter clockwise 'locked' the trunk where the button on the remote and the interior worked if the doors were locked but did not allow the trunk to be opened if the car was locked.
Old Oct 27, 2012 | 07:13 PM
GTA_Driver's Avatar
Tech Guru
It's all about the position of the key in the trunk lock. You can leave it straight (at 6 and 12 o'clock) or turn left and then return to vertical, or right and then vertical. One of the positions will not lock the trunk, and the other one will. Experiment.
Old Oct 28, 2012 | 03:37 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Got VAG-COM? Do some testing.
Old Oct 29, 2012 | 02:39 AM
Default Trunk does not lock
Thanks for the 6 / 12 o'clock settings ....I remember that from years ago. However, still has not fixed the problem. Seems like something may be out of alignment in the trunk and the electronics are not able to connect.
Using the key fob - will still not lock the trunk.
Could there be a small alignment issue? Or is there potentially an electronics issue in the trunk?
jim
Old Oct 29, 2012 | 03:42 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
If you hear clunks while fob locking or unlocking it is likely not electronic. Does the switch on the door sill work the trunk?
Kerry G
May 18, 2018 06:12 AM
visuar
TT (Mk3) Discussion
10
Nov 14, 2017 01:56 PM
gorkyc
Oct 4, 2015 07:00 PM
Tman007
A7
10
Oct 1, 2015 07:25 PM
ebod0000
A6 (C7 Platform) Discussion
Sep 30, 2015 10:27 AM
