Under Engine Cover Fasteners
#11
That's funny...I slide in the front, get the sides inside the fender well liners, and then put in the outside back pins and then the center back before I get to the fronts. I use a pin punch to line up the front middle and then same fro the two outside ones.
I've had to repair the belly pan two or three times now...using JB weld and fiber-reinforced bondo. Several times had to replace those clips on the belly pan for the side fenderwell fasteners, as well as the lost fasteners.
You're right....speed nuts and bolts would have been a lot cheaper and stronger.
mshan
01-11-2008 04:08 PM
pakboy
11-11-2000 03:43 PM
