Wierd radio problem solved...
Old 03-20-2007, 06:12 PM
New Member
StartXJeff's Avatar
Default Wierd radio problem solved...
When I got in the A6 in the morning, the radio was in limbo mode. (radio wouldn't turn on, radio wouldn't turn off, radio cluster lights stayed on with a blank screen).
Opened fuse access, pulled fuse 37, fuse was okay - so put fuse back. Wala... radio worked fine. It didn't even trigger safe mode.
So... what do y'all think? Common issue? If it happens again, how much (typical cost) to replace a radio? I suppose I could source a 3rd party radio. Or, maybe the battery (??)... just too wierd.
Old 03-21-2007, 05:16 AM
AudiWorld Expert
Boston Driver's Avatar
Default Sounds like your "reboot" took care of it...
...Pulling the fuse seems to have solved the problem this time, but maybe a VAG COM might give you some hints about what might have happened.
Old 03-21-2007, 05:24 AM
Tundraman's Avatar
Default Re: Wow, this is so wierd, I had this exact thing happen to me this past Friday
on the way home from work. I did the same thing, and voila, it worked, with no safe mode. I tried turning it on/off a number of times, nothing, start/stopped the car, it stayed "lit up" lights, but no display. strange. Pulled the fuse and put it back in. works fine now, and no safe mode.
-Tundraman
Old 03-21-2007, 08:43 AM
New Member
StartXJeff's Avatar
Default yeah... I know. No code. BUT.....
I did smell smoething when I opened the fuse
access. I was afraid that I might have an
arcing issue. A799, no code, no fault, and no issue at the time other than the blank "on" radio that wouldn't turn off.
If it happens again, I think I'll take it to the dealer and have them look for a code while it's "on" before I do anything else.
It's the only electrical issue that I've ever had, other than a blinker deallybob replacement.
Old 03-21-2007, 09:25 AM
iProDrive's Avatar
Default Be carefull what you say...*knock on wood*
""It's the only electrical issue that I've ever had, other than a blinker deallybob replacement.""
You just might get more than what you bargain for ;-)
papuc (MMI S4)
11
05-02-2020 07:38 AM
ahaiceman
11-28-2009 10:51 AM
papuc (MMI S4)
07-18-2008 02:18 PM
KO4IAIN
10-30-2006 06:30 AM
brian
12-01-1999 08:33 PM
Quick Reply: Wierd radio problem solved...
