3.0T intake issues
3.0T intake issues
Help!! I have a 2010 A6 3.0T supercharged engine. I love this car. Recently, the oil canister was broken by a younger mechanic during an oil chance. Very frustrating. Repairing this has let to many broken parts that were brittle with age. Finally, i am on the way back together. Only when i reinstall it he lower intakes, the Venturi hit the intake valve baffle. I can not figure any way to adjust this. New seals have not helped. Audi will not take my call. WTF is going on. Latterly nothing has changed to make this happen. Has anyone else had this issue and how was it corrected? I see on some forums with the 3.0 TDI they are deleting the Venturi and baffle for increased power? Not sure if this applies to the gas variant or is even factual.....
I’m fuzzy on the details, but I think it’s been mentioned on here in connection with carbon cleaning, that when reassembling the intake manifold you have to hold the actuator so the flaps are open while you put into place and bolt down the manifold. Otherwise the flap will sit on the wrong side of the dividers and cannot open properly (or is it close fully?). This was in connection with the 3.2 motor, but may also apply to yours. Someone with first hand knowledge will hopefully add a comment, but hopefully this will set you on the right track.
Are you taking about the intake runner flaps hitting the plates in the cylinder head? Yes it will cause a check engine light and flap bank 1 and 2 stuck closed. You have to remove all the fuel rail screws and pull the assembly up off the head slightly. Then with your finger actuator rod connected to the vacuum diaphragm and with your finger manually pull it all the way open and then seat the rail back onto the cylinder head. Still holding it opened install 2 screws in the middle on top and bottom and then release. Install the rest of the screws, repeat on the other side and you should be good to go.
-Cheers
-Cheers
jeckees22
03-19-2007 12:45 PM
ryan@s4.org(nogaro_s4)
Motorsport Discussion
10-05-2000 08:38 AM
