A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Battery disconnecting question
Old 10-17-2021, 06:18 PM
Noud's Avatar
Default Battery disconnecting question
Hey there,
With my current job, i get to drive my 06 A6 for a few days every 10-14 days, i thought to install easy battery disconnect switch on my negative battery terminal or just simply disconnect it while I am away and only connect when I am back home.
Question is, how safe are these switches and would it harm the car to constantly disconnecting the battery?
My worry is that disconnected battery will reset all adaptation and car will go into “learning” mode every two weeks. Does Audi likes that?
Old 10-18-2021, 08:46 AM
jeffpuxx's Avatar
Just curious, but why do you even want to do this?
Old 10-18-2021, 08:55 AM
Noud's Avatar
my battery drains
Old 10-18-2021, 09:08 AM
UCLABB's Avatar
Originally Posted by Noud
my battery drains
Get a relatively inexpensi8ve battery tender. But, if you dive a few days every 10-14 days, I doubt you need anything.
Old 10-18-2021, 02:11 PM
Noud's Avatar
got it!
but i am curious from technical side. Would often resets hurt car?
Old 10-18-2021, 03:46 PM
beep-beep's Avatar
got it!
but i am curious from the technical side. Would often resets hurt car?
Audi attempted to develop its own battery disconnect - the battery computer. It tries to sort out how much battery energy left and shuts down some circuits after another. It has five levels of these circuits.
If you will disconnect the power yourself - it will cause all car's computers to lose their memory. I do not think it is the best approach. It mean every time you drive the ECM will learn the engine parameters and you will need to teach the seat its position and radio its stations.
Of course, if you can use tender - go for it. Just be sure that you connect to the terminals under the hood and not in the trunk.
I think a fair question is why the battery drains? It should survive for 2 weeks without driving. There is a way to find what causes the battery to drain. You need to connect milliampermetter between the battery and the wire. turn off the car; remove one fuse at a time and see where the current from the battery will drop to 50mA. I did it when my battery was draining. I found that some of the MMI devices did not fall to sleep and continued consuming power after the car was locked. There are some youtube videos how to do it.
is one .
UCLABB (10-19-2021)
Old 10-19-2021, 06:30 PM
Sallad's Avatar
Originally Posted by beep-beep
...question is why the battery drains? It should survive for 2 weeks without driving.
I'd look into this first.
Old 10-19-2021, 06:37 PM
Noud's Avatar
I guess Ill have to start poking with my multimeter. Im pretty sure its something MMI related, nothing else seems possibly stay on.
Buck863
Audi e-tron / Q8 e-tron
38
03-28-2021 10:32 AM
2003Quattro1.8T
06-08-2007 07:57 PM
red90q
10-25-2006 05:59 PM
f3d
02-24-2005 09:19 PM
Quick Reply: Battery disconnecting question
