A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
EE: Vcds- Can gateway (ecu faulty coded)
Old 03-28-2022, 12:18 PM
jonas001's Avatar
Default EE: Vcds- Can gateway (ecu faulty coded)
Hello
VCDS is saying my can is faulty coded, which is true. I'm having issues with mmi features, such as few options are grayed out in the car menu, which are:
1) central locking
2) service interval
3) background lightning
​​​​​4) windows
All of them are actually on car and are working, but I'm not able to click or change them in mmi screen.
Afterall I'm not able to change the date and time (date and time are different on instruments and mmi screen, on mmi screen clock is stuck at 0:00).
Also changing temperature, fan speed, etc. in climate panel doesn't show up on mmi screen
Can anyone guide me to code ecu correctly (I assume it's all related to faulty code)?
​​​​​​I don't have any info what coding was before, cause car was bought on auction and don't have any history who and why has changed ecu codings.
Mmi 2g High
Old 03-31-2022, 10:54 AM
das60's Avatar
Are those MMI or Green Screen issues? Maybe accessible in both, I do not know. Be careful with changing things.
https://www.motor-talk.de/forum/akti...hmentId=787244
jonas001 (04-01-2022)
Old 03-31-2022, 02:08 PM
jonzie77's Avatar
Those are available from the green screen though it is harder to navigate than using VCDS, it kinda depends on how good your German is. You would normally need VCDS to enable the service menu (green screen) but I suspect that was done by a previous owner and then he/she went in and messed it up.
The following 2 users liked this post by jonzie77:
das60 (03-31-2022), jonas001 (04-01-2022)
Old 04-01-2022, 10:21 PM
jonas001's Avatar
Yeah, you were right. It was enabled by previous owner.
It was helpful, and were accessable from green menu
Thanks to both of you guys for your help! It worked out for me.
Solution:
Went to green menu, diag settings > APK 0x0D, changed settings from BAP to CDEF (no idea what they means), but now are everything clickable under car menu
The following 2 users liked this post by jonas001:
das60 (04-02-2022), jonzie77 (04-02-2022)
slowguy
32
10-01-2012 03:29 AM
A3.2QMax
Audi A3 / S3 / RS 3
12-29-2005 04:59 PM
agent s
07-30-2001 10:03 AM
Paul H. (near Annapolis, MD)
Performance and Tuning
06-14-2001 09:00 AM
audidriver27t
9
04-03-2001 04:25 AM
Quick Reply: EE: Vcds- Can gateway (ecu faulty coded)
