Gearbox and MMI - 2008, A6 C6 Quattro 3 TDi
Howdy...
Second-hand Quattro with a few kms on it. A few issues that are simple enough to deal with (glowplugs and engine mount), but there are 2 issues that aren't.
VCDS output to follow.
1. MMI works sporadically, fine in the morning when it's cool, but after second start turning on and off, etc. Found and replaced one blown 5amp fuse (in the rear, right of the trunk). I think it was for the aerial amp, but there was no chart to indicate what it did. Didn't fix problem.
All other fuses checked with multimeter - all good.
2. Tranny failsafe PRNDS occurred a couple of weeks back, can drive in manual no problems after restart. Workshop replaced fluid and filter (no residue to suggest mechanical failure). A day later, the PRNDS happened again - and I was able to isolate the issue/s on VCDS (009986 - Transmission Friction Element / Clutch C P2702) I was hoping for a ECU problem, mechanic thinks it's worse than that.
I'd really appreciate a quick scan of the output and if anything jumps out - please let me know...
Friday,15,September,2017,13:50:47:17521
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
VCDS Version 17.8.0.1 HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
Ross-Tech: Home
Mileage: 292100km-181502mi Repair Order: AFter Start
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 34 37 42 46 47 4F 52
53 55 56 61 62 67 69 6C 72 76 77
Mileage: 292100km-181502miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 1010
67-Voice Control -- Status: Sporadic communication error 1000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F9 910 401 L HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 01205 001 1048576
VCID: 2E060682EC130267F96-807B
8 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291149 km
Time Indication: 0
Date: 2017.08.25
Time: 17:31:11
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 11:46:16
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 10.64 V
Bin. Bits: 00101000
Torque: 109.2 Nm
Bin. Bits: 00000100
005667 - Powertrain Data Bus
P1623 - 000 - No Communication - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 693 /min
Torque: 148.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.17 V
Bin. Bits: 00001000
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 C HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H04--- Serial number: 4434600
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 280AF09ACEF75C5733A-807D
4 Faults Found:
006288 - Signal Line for Tiptronic
P1890 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
P2702 - 000 - Apply Time Implausible - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 291988 km
Time Indication: 0
Date: 2017.09.13
Time: 14:21:50
006228 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 292100 km
Time Indication: 0
005889 - Transmission Control Unit
P1701 - 000 - Locked - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 292100 km
Time Indication: 0
Address 03: ABS Brakes Labels:
VCID: 55F4896EAC0511BF58C-FFFF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601501032021
Coding: 0000147
Shop #: WSC 21200 822 92139
VCID: 6390A7B6F751FF0F268-8037
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H01 0040
5 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:03
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 239
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 16:20:18
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:52
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:52
00263 - Transmission
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000506830
Coding: 0001366
VCID: 1C62DC4A8AAF80F7A72-8049
4 Faults Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 239
Mileage: 291885 km
Time Indication: 0
Date: 2017.09.13
Time: 09:37:42
Freeze Frame:
Bin. Bits: 00001111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:10
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:10
Freeze Frame:
ON
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:15
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0002121
Shop #: WSC 02335 785 00200
VCID: 313C1DFEFD2D1D9FE44-8065
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
3 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 15
Reset counter: 237
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.01
Time: 17:22:00
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 224
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.01
Time: 16:24:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.01
Time: 17:14:00
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0X3W3T
Coding: 0013382
VCID: 290CF59ED5FD655F2C4-807D
Subsystem 1 - Serial number: 6332CSME2B732530.
Subsystem 2 - Serial number: 6342CSME2B7436724
Subsystem 3 - Serial number: 6352QSME596E2239R
Subsystem 4 - Serial number: 6362QSME5811483BJ
Subsystem 5 - Serial number: 63734SME585A47232
Subsystem 6 - Serial number: 63834SME4E701F314
1 Fault Found:
01316 - ABS Control Module
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025080600121
Coding: 0102142
Shop #: WSC 02323 785 00200
VCID: 2708F3A6C3E9532F3A0-8073
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:46
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 239
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:16:59
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 6XX75A638
Coding: 7209758
Shop #: WSC 00675 675 00005
VCID: 2310E7B6B7D1BF0F668-8077
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 16:17:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:07
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:07
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B083078012
Coding: F751DE7F70720600
VCID: 2D04018EE115797FC0C-8079
6 Faults Found:
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 291440 km
Time Indication: 0
Date: 2017.08.30
Time: 15:47:36
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 228
Mileage: 291440 km
Time Indication: 0
Date: 2017.08.30
Time: 15:47:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:17:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:53
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:57
Address 1E: Media Player 2 Labels:
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0060
Serial number: 00619004580100
Coding: 0000220
VCID: 221EE2B2A8CBB6076DE-8077
3 Faults Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 11
Reset counter: 236
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 11:46:17
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 291642 km
Time Indication: 0
Date: 2017.09.05
Time: 19:08:41
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 241
Time Indication: 0
Address 37: Navigation Labels:
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 F HW: 4F0 959 793 F
Component: TSG FA H21 0210
Coding: 0001562
Shop #: WSC 02327 785 00200
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:55
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:55
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01103044250000
Coding: 0393869
Shop #: WSC 20690 822 59815
6 Faults Found:
02933 - Control Circuit for Brake Light in Trunk/Hatch Lid; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 18
Reset counter: 236
Mileage: 291440 km
Time Indication: 0
Date: 2017.08.31
Time: 12:59:23
02931 - Control Circuit for Brake Light in Fender; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 234
Mileage: 291788 km
Time Indication: 0
Date: 2017.09.08
Time: 17:40:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:58
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:08
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000158971
Coding: 0001013
VCID: 5EE69642DC33D2E7096-800B
5 Faults Found:
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Time Indication: 0
Freeze Frame:
Voltage: 11.800 V
Not Recogn.
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Not Recogn.
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Not Recogn.
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Not Recogn.
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Temperature: 20.0∞C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 F HW: 4F0 959 792 F
Component: TSG BF H21 0210
Coding: 0001562
VCID: 2C020C8ADA0F7077D72-8079
2 Faults Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 200
Mileage: 291801 km
Time Indication: 0
Date: 2017.09.10
Time: 14:54:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Time Indication: 0
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02145 785 00200
VCID: 201AE8BAA6C7A4177BA-8075
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292096 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Voltage: 10.87 V
Count: 241
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292096 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Voltage: 10.87 V
Count: 243
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Mileage: 292096 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Voltage: 10.87 V
Count: 242
01487 - System Function Test
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 236
Time Indication: 0
Freeze Frame:
Voltage: 0.00 V
Count: 184
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 3FD84BC63B79FBEF620-806B
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 241
Mileage: 292104 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 241
Mileage: 292104 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 241
Mileage: 292104 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000047184
VCID: 2412E4AAB2DFB8371F2-8071
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 29940YUASA
Coding: 344630393135313035442056413032393934305955415341
Shop #: WSC 00000 384 00290
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:10
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0210
Coding: 0001026
VCID: 2F381B86EB190B6FF20-807B
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:52
Address 67: Voice Control
Cannot be reached
Address 69: Trailer (J345) Labels:. 4F0-907-383.clb
Part No SW: 4F0 907 383 C HW: 4F0 907 383 C
Component: Anhaenger H14 0080
Revision: 2B002001 Serial number: 00000107892393
Coding: 0100000000000003
VCID: 2B000F96D301774FDE8-807F
3 Faults Found:
011 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Time Indication: 0
Date: 2063.15.31
Time: 16:03:63
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:05
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:05
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8230WP
Coding: 1020305
VCID: 1E66D6429CB392E7496-804B
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 16:24:17
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:05
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0210
Coding: 0001026
No fault code found.
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06340807116252
Coding: 0221416
Shop #: WSC 131071 1023 2097151
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:05
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005116187
Coding: 0010900
VCID: 2A0E0A92D0FB6E4725E-807F
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:21
End----------(Elapsed Time: 01:58, VBatt start/end: 13.2V/13.2V)-----------
Ross-Tech: Home
Coding: 0011372
8 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291149 km
Time Indication: 0
Date: 2017.08.25
Time: 17:31:11
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 291152 km
Time Indication: 0
Date: 2017.08.26
Time: 08:01:10
Freeze Frame:
RPM: 1722 /min
Torque: 284.7 Nm
Speed: 20.2 km/h
Duty Cycle: 28.9 %
Voltage: 13.45 V
Duty Cycle: 23.7 %
Temperature: 16.2∞C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 11:46:16
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 10.64 V
Bin. Bits: 00101000
Torque: 109.2 Nm
Bin. Bits: 00000100
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 693 /min
Torque: 148.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.17 V
Bin. Bits: 00001000
Coding: 0000001
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 291988 km
Time Indication: 0
Date: 2017.09.13
Time: 14:21:50
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 292100 km
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 292100 km
Time Indication: 0
Coding: 0000147
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 239
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 16:20:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Cannot be reached
Coding: 0001366
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 239
Mileage: 291885 km
Time Indication: 0
Date: 2017.09.13
Time: 09:37:42
Freeze Frame:
Bin. Bits: 00001111
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:10
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:10
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:15
Coding: 0002121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 237
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.01
Time: 17:22:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 224
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.01
Time: 16:24:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.01
Time: 17:14:00
Cannot be reached
Coding: 0013382
1 Fault Found:
Coding: 0102142
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:46
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 239
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:16:59
Coding: 7209758
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 16:17:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:07
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 291440 km
Time Indication: 0
Date: 2017.08.30
Time: 15:47:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 228
Mileage: 291440 km
Time Indication: 0
Date: 2017.08.30
Time: 15:47:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:17:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:57
Coding: 0000220
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 236
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 11:46:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 291642 km
Time Indication: 0
Date: 2017.09.05
Time: 19:08:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 241
Time Indication: 0
Coding: 0001562
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:55
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:55
Coding: 0393869
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 236
Mileage: 291440 km
Time Indication: 0
Date: 2017.08.31
Time: 12:59:23
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 234
Mileage: 291788 km
Time Indication: 0
Date: 2017.09.08
Time: 17:40:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:58
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:08
Cannot be reached
Coding: 0001013
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Time Indication: 0
Freeze Frame:
Voltage: 11.800 V
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 262136 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:00
Freeze Frame:
Voltage: 11.700 V
Temperature: 20.0∞C
Coding: 0001562
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 200
Mileage: 291801 km
Time Indication: 0
Date: 2017.09.10
Time: 14:54:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 241
Time Indication: 0
Revision: --H04---
Coding: 0000321
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292096 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Voltage: 10.87 V
Count: 241
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292096 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Voltage: 10.87 V
Count: 243
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Mileage: 292096 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Voltage: 10.87 V
Count: 242
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 236
Time Indication: 0
Freeze Frame:
Voltage: 0.00 V
Count: 184
Coding: 0000004
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 241
Mileage: 292104 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 241
Mileage: 292104 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 241
Mileage: 292104 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Address 56: Radio
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:10
Coding: 0001026
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:21:52
Cannot be reached
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Time Indication: 0
Date: 2063.15.31
Time: 16:03:63
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:05
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:34:05
Coding: 1020305
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 16:24:17
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:05
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Coding: 0001026
Coding: 0221416
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:05
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 241
Mileage: 292100 km
Time Indication: 0
Date: 2017.09.15
Time: 13:31:06
Coding: 0010900
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 291442 km
Time Indication: 0
Date: 2017.09.01
Time: 17:15:21
Just thought I'd update this as I go through the various issues with mechanics and dealerships. I live ~800kms remotely, so would appreciate any thoughts.
MMI
Mechanic thinks the AMP is on the way out, I found some second hand units online, but he said that they won't work due to component protection - and that Audi won't remove it? I wasn't aware that you couldn't simple swap out certain components without being forced to buy them directly from the dealerships. Is this correct? I'm wondering whether this is an Australian thing - as there seems to be quite a lot of second hand cp protected units on the internet being bought and sold.
I've reached out to Storka to see if I can get the CP removed that's causing the issues above, so that I can try and isolate the problem.
Transmission
I spoke to a rebuilder who thinks it may be a worn bush on the clutch - they'd have to pull it out to diagnose. $5K rebuild. I think the car is now a manual. I haven't had the issue occur driving in manual, so I'm hoping that will be OK. I guess there's no other way to diagnose a problem like this, without disassembling the transmission. Wondering if a new transmission might be a better option?
MMI
Transmission
Here's the most recent VCDS output:
(*note that the transmission fault is currently cleared)
Friday,22,September,2017,11:05:44:17521
Ross-Tech: Home
VIN: WAUXXXXXXXXXXXXX License Plate:
Mileage: 292400km-181688mi Repair Order: after clearing
VIN: WAUXXXXXXXXXXXXXX Mileage: 292400km-181688miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: Cannot be reached 1100
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Coding: 0011372
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 292361 km
Time Indication: 0
Date: 2017.09.21
Time: 15:04:26
Freeze Frame:
RPM: 756 /min
Torque: 46.8 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Readiness: 0 0 0 0 0
Coding: 0000001
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Revision: 00000000 Serial number: 00000000000000
Coding: 0000392
Shop #: WSC 21200 822 103906
VCID: 6492A4AAF25FF837DF2-8031
Coding: 0000147
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 K HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 351CX087559582
Coding: 0003002
VCID: 2B000F96DF01774FDE8-807F
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001022212
Subsystem 3 - Serial number: 0111.03.080000000100010943ÿ
Subsystem 4 - Serial number: 010943ÿ
Coding: 0001366
Coding: 0002121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
Coding: 010000
Shop #: WSC 02399 823 56573
VCID: 290CF59ED9FD655F2C4-807D
Coding: 0013382
Coding: 0102142
Coding: 7209758
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 211
Mileage: 292405 km
Time Indication: 0
Date: 2017.09.22
Time: 10:44:22
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8339096
Shop #: WSC 00000 000 00000
VCID: 1A6EDA52809BFEC7B5E-804F
Coding: 0000220
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 364C.087771829
VCID: 3B203FD62F61E7CF4E8-806F
Coding: 0001562
Coding: 0393869
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1400000
Coding: 030101
VCID: 280AF09AC2F75C5733A-807D
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 251
Mileage: 292405 km
Time Indication: 0
Date: 2017.09.22
Time: 10:41:32
Freeze Frame:
Voltage: 13.20 V
Temperature: 45.0°C
Bin. Bits: 00000111
Coding: 0001013
Coding: 0001562
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 292405 km
Time Indication: 0
Date: 2017.09.22
Time: 10:41:27
Revision: --H04---
Coding: 0000321
Coding: 0000004
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394C4087877676
Coding: 0000001
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 12
Reset counter: 210
Mileage: 286087 km
Time Indication: 0
Date: 2017.05.25
Time: 15:23:20
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 12
Reset counter: 210
Mileage: 286087 km
Time Indication: 0
Date: 2017.05.25
Time: 15:23:21
Coding: 0001026
Cannot be reached
Coding: 1020305
Coding: 0001026
Coding: 0221416
Coding: 0010900
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End----------(Elapsed Time: 01:58, VBatt start/end: 13.1V/13.1V)-----------
Ross-Tech: Home
Coding: 0011372
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 292361 km
Time Indication: 0
Date: 2017.09.21
Time: 15:04:26
Freeze Frame:
RPM: 756 /min
Torque: 46.8 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Coding: 0000001
Coding: 0000392
Coding: 0000147
Coding: 0003002
Coding: 0001366
Coding: 0002121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Revision: 00000000
Coding: 010000
Coding: 0013382
Coding: 0102142
Coding: 7209758
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 211
Mileage: 292405 km
Time Indication: 0
Date: 2017.09.22
Time: 10:44:22
Coding: 0000220
Coding: 0001562
Coding: 0393869
Revision: S1400000
Coding: 030101
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 251
Mileage: 292405 km
Time Indication: 0
Date: 2017.09.22
Time: 10:41:32
Freeze Frame:
Voltage: 13.20 V
Temperature: 45.0°C
Bin. Bits: 00000111
Coding: 0001013
Coding: 0001562
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 292405 km
Time Indication: 0
Date: 2017.09.22
Time: 10:41:27
Revision: --H04---
Coding: 0000321
Coding: 0000004
Coding: 0000001
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 210
Mileage: 286087 km
Time Indication: 0
Date: 2017.05.25
Time: 15:23:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 210
Mileage: 286087 km
Time Indication: 0
Date: 2017.05.25
Time: 15:23:21
Coding: 0001026
Cannot be reached
Coding: 1020305
Coding: 0001026
Coding: 0221416
Coding: 0010900
No Faults Found
And the optical bus scan is good:
Control Module Part Number: 4L0 910 468 A
Component and/or Version: J533__Gateway H06 0060
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
1E-Media Player 2 OK OK
77-Telephone OK OK
47-Sound System OK OK
67-Voice Control OK OK
56-Radio OK OK
37-Navigation OK OK
77-Telephone OK OK
56-Radio OK OK
37-Navigation OK OK
I've managed to fix all of this, and have posted another thread detailing it (given no responses to this) - just awaiting the moderator to approve it.
Titua1915
9
01-18-2015 06:37 PM
mattmondo
Audi 100 / A6 (C4 Platform)
08-06-2009 08:10 AM
