How to disable mirror fold-in motor?
Hi all,
Does anyone have a clever way to disable the mirror fold-in motor, without also disabling mirror adjustments and heating?
It appears that the position sensor is faulty, resulting in the mirror to occasionally to fold _forwards_ when the car engine is started. Wors case I'll have to remove the corresponding fuse, but that seems a bit of an overkill.
Cheers,
Pal
Cheers,
Pal
For my car, I just have the mirror selector NOT on the Folding Mirror icon. I have my **** on the Right Side mirror (this allows the mirror to dip when the car is put into reverse). Winter I turn it to the heated selection for a few mins, then back to Right Side selection.
Have you opened up the mirror and had a look? Something must tell the mirror motor to stop at certain positions. Physical limit switches or a magnetic Hall effect sensor type setup?
jonzie77 (12-05-2023)
OP,
I have 2 C6 A6's, one pre, one post facelift. Mirror folding was never automatic, but always a function of the mirror position switch. It sounds like either the previous owner installed a module in the door to make this automatic (they sell them on aliexpress), or the mirror switch in the door is defective. Are you able to post an autoscan of the vehicle coding and any fault codes?
-Cheers!
-Cheers!
Moonlightblue
A6 (C7 Platform) Discussion
11-23-2023 10:21 AM
vtraudt
09-17-2013 10:28 AM
Gr8White
08-26-2012 11:35 PM
