Interior Lights Only Work When Car is Off
I have a 2007 Audi A6 and my interior lights only work when I'm first getting in the car. Once I've stuck the key in the ignition none of the interior lights work including the reading lights. At the end of a trip, after I take out the key and open the doors, still no interior lights. Once the car has been locked and sitting for a while, I can repeat the above.
I read of a similar problem here: A6 C6 Interior Light problem
The explanation being that the interior lighting module could've been swapped and that there's some anti-theft unlocking that needs to be done. Seems plausible as the carfax on this car shows that it was a theft recovery early in its life. I dug through the erwin manuals and it just says to click a "new module" button on the shop software when swapping modules so that wasn't much help to me.
I also came across this Ross-Tech post: Immobilizer III ECU Swapping - Ross-Tech Wiki. Not sure if it applies to all electrical modules but if it does, how do I know what the PIN is when this is how I bought the car?
Has anyone had this issue before and solved it? Is there a way to unlock the module via VCDS or am I going to have to take this to a dealer?
Not sure exactly which module to be looking at but nothing jumps out at me. Here's the log:
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000431022
Coding: 0000011
Shop #: WSC 58444 001 1048576
VCID: 6390A79EB753CADF268-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0054
1 Fault Found:
00288 - Steering Column Lock Actuator (N360)
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 09:39:34
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303EF067523225
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 313C1DD6BD2F284FE44-8064
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000425047
Subsystem 3 - Serial number: 0123.05.060000000100010752ÿ
Subsystem 4 - Serial number: 010752ÿ
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 27
Reset counter: 141
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:43:58
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000000268843
Coding: 0524326
Shop #: WSC 02325 785 00200
VCID: 5BE09F7E8F23F21F6E8-800E
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 49
Reset counter: 48
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:18
Freeze Frame:
Temperature: 39.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0114123
VCID: 303A18D2B6252147EBA-8064
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
No fault code found.
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8124110
Shop #: WSC 00000 000 00000
VCID: 1C62DC62CAADB527A72-8048
1 Fault Found:
02244 - Button in Control Head is Stuck
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 7
Fault Frequency: 4
Reset counter: 143
Mileage: 156357 km
Time Indication: 0
Date: 2017.10.16
Time: 09:07:02
Freeze Frame:
Bin. Bits: 00010000
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 950 S
Component: KOMBIINSTR. M73 H12 0070
Revision: 00100000 Serial number: 5F5593C56
Coding: 2129203
Shop #: WSC 08175 444 84038
VCID: 201AE892E6C591C77BA-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 130080651881D1
Coding: 6CFE73CD1B3104
Shop #: WSC 02334 785 00200
VCID: 2708F38E83EB66FF3A0-8072
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 11
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:11
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:57:06
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 619CAD96AD4FD8CF344-8034
2 Faults Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
00003 - Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000001204
Coding: 0000016
Shop #: WSC 02323 785 00200
VCID: 2514F986F9E774EF08C-8070
1 Fault Found:
02457 - Loudspeaker in Hat Shelf (R150)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 143
Mileage: 152500 km
Time Indication: 0
Date: 2017.08.15
Time: 18:19:48
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000024727
Coding: 0002014
VCID: 5EE6966A9C31E737096-800A
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394E/067644956
Coding: 0000002
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.26
Time: 17:26:22
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000038574
Shop #: WSC 08251 444 83875
VCID: 2310E79EF7D38ADF668-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2605171080
Coding: 344630393135313035442056413032363035313731303830
Shop #: WSC 00000 384 00290
5 Faults Found:
02274 - Quiescent Current Stage 3
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 53
Reset counter: 255
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:02:00
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 98
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.22
Time: 21:23:59
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 67
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.23
Time: 02:27:19
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 39
Reset counter: 255
Mileage: 155424 km
Time Indication: 0
Date: 2017.10.06
Time: 03:00:34
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 15:45:09
Address 62: Door, Rear Left
Cannot be reached
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900021074
Coding: 0062221
VCID: 221EE29AE8C983D76DE-8076
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007530644
Coding: 0010990
VCID: 280AF0B28EF5698733A-807C
End----(Elapsed Time: 01:23, VBatt start/end: 11.4V/11.4V. VIgn 0.0V)------
Thursday,19,October,2017,18:01:37:26412
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
Ross-Tech: Home
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
55 56 61 62 65 72 77
Mileage: 156580km-97294miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Ross-Tech: Home
Chassis Type: 4F0
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000011
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 09:39:34
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 27
Reset counter: 141
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:43:58
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 49
Reset counter: 48
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:18
Freeze Frame:
Temperature: 39.0°C
Coding: 0114123
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 143
Mileage: 156357 km
Time Indication: 0
Date: 2017.10.16
Time: 09:07:02
Freeze Frame:
Bin. Bits: 00010000
Address 15: Airbags
Cannot be reached
Cannot be reached
Coding: 2129203
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 11
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:57:06
Coding: 0082946
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 143
Mileage: 152500 km
Time Indication: 0
Date: 2017.08.15
Time: 18:19:48
Coding: 0002014
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.26
Time: 17:26:22
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Reset counter: 255
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:02:00
Freeze Frame:
Fault Priority: 7
Fault Frequency: 98
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.22
Time: 21:23:59
Freeze Frame:
Fault Priority: 7
Fault Frequency: 67
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.23
Time: 02:27:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 39
Reset counter: 255
Mileage: 155424 km
Time Indication: 0
Date: 2017.10.06
Time: 03:00:34
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 15:45:09
Cannot be reached
Coding: 0062221
Cannot be reached
Coding: 0010990
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000011
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 09:39:34
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 27
Reset counter: 141
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:43:58
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 49
Reset counter: 48
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:18
Freeze Frame:
Temperature: 39.0°C
Coding: 0114123
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 143
Mileage: 156357 km
Time Indication: 0
Date: 2017.10.16
Time: 09:07:02
Freeze Frame:
Bin. Bits: 00010000
Address 15: Airbags
Cannot be reached
Cannot be reached
Coding: 2129203
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 11
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:57:06
Coding: 0082946
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 143
Mileage: 152500 km
Time Indication: 0
Date: 2017.08.15
Time: 18:19:48
Coding: 0002014
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.26
Time: 17:26:22
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Reset counter: 255
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:02:00
Freeze Frame:
Fault Priority: 7
Fault Frequency: 98
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.22
Time: 21:23:59
Freeze Frame:
Fault Priority: 7
Fault Frequency: 67
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.23
Time: 02:27:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 39
Reset counter: 255
Mileage: 155424 km
Time Indication: 0
Date: 2017.10.06
Time: 03:00:34
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 15:45:09
Cannot be reached
Coding: 0062221
Cannot be reached
Coding: 0010990
Ross-Tech: Home
Chassis Type: 4F0
Ross-Tech: Home
Chassis Type: 4F0
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000011
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 09:39:34
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 27
Reset counter: 141
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:43:58
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 49
Reset counter: 48
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:18
Freeze Frame:
Temperature: 39.0°C
Coding: 0114123
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 143
Mileage: 156357 km
Time Indication: 0
Date: 2017.10.16
Time: 09:07:02
Freeze Frame:
Bin. Bits: 00010000
Address 15: Airbags
Cannot be reached
Cannot be reached
Coding: 2129203
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 11
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 152473 km
Time Indication: 0
Date: 2017.08.15
Time: 17:57:06
Coding: 0082946
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 152472 km
Time Indication: 0
Date: 2017.08.15
Time: 17:56:05
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 143
Mileage: 152500 km
Time Indication: 0
Date: 2017.08.15
Time: 18:19:48
Coding: 0002014
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.26
Time: 17:26:22
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Reset counter: 255
Mileage: 154040 km
Time Indication: 0
Date: 2017.09.17
Time: 09:02:00
Freeze Frame:
Fault Priority: 7
Fault Frequency: 98
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.22
Time: 21:23:59
Freeze Frame:
Fault Priority: 7
Fault Frequency: 67
Reset counter: 255
Mileage: 152893 km
Time Indication: 0
Date: 2017.08.23
Time: 02:27:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 39
Reset counter: 255
Mileage: 155424 km
Time Indication: 0
Date: 2017.10.06
Time: 03:00:34
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 156580 km
Time Indication: 0
Date: 2017.10.19
Time: 15:45:09
Cannot be reached
Coding: 0062221
Cannot be reached
Coding: 0010990
Step 1 - Clear ALL codes and logs and re-run the clear at each one of the modules
Step 2 - re-run the log
Based upon a quick look, how old is your battery and how good is it...Based upon the "Quiescent Current" errors, I believe your battery is dying and your electronics system mgmt. is attempting to ensure only vital systems are powered as appropriate.
You have a LOT of faults, heck only a few modules are actually "status: OK":
Ok here's the new scan with the vehicle running. Much cleaner. Anything here that you think points at the weird interior light issue?
.00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 C HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0070
Revision: --H19--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 08175 444 10346
VCID: 2C020CA29A0D45A7D72-8078
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 G HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H01--- Serial number: 4187773
Coding: 0000002
VCID: 290CF5B695FF508F2C4-807C
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0021407
VCID: 6696BE8A4461BFF7C16-8032
Coding: 0000011
Coding: 0000003
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 158235 km
Time Indication: 0
Date: 2017.11.13
Time: 21:54:56
Freeze Frame:
Temperature: 15.0°C
Coding: 0114123
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00146221
Shop #: WSC 02335
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH30 0320
Revision: 16H30000 Serial number: 00359D0J4C4Q
Coding: 0013878
VCID: 2A0E0ABA90F95B9725E-807E
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0E4266384
Subsystem 3 - Serial number: 6342CSME0F2F5C11D
Subsystem 4 - Serial number: 6352QSME10103B7FF
Subsystem 5 - Serial number: 6362QSME10421039+
Subsystem 6 - Serial number: 63734SME0E63293B6
Subsystem 7 - Serial number: 63834SME0C6C1D0DG
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H02000 Serial number: 90025061200478
Coding: 0012241
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Coding: 2129203
Coding: 0082946
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 177
Mileage: 158232 km
Time Indication: 0
Date: 2017.11.13
Time: 21:54:50
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 158232 km
Time Indication: 0
Date: 2017.11.13
Time: 21:54:50
Cannot be reached
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: !Va
Coding: 0035563
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01002222260000
Coding: 0423997
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 13:03:46
02103 - Control Module 2 for Vehicle Electrical System (J520)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 14:18:24
Coding: 0000016
Coding: 0002014
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: Hb
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0005022
Shop #: WSC 02324 785 00200
VCID: 1F18EB6EDBBBAE3F420-804A
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Coding: 0000002
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0035370
VCID: 2E0606AAAC1137B7F96-807A
Coding: 0062221
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0035370
Coding: 0010990
End----------(Elapsed Time: 01:43, VBatt start/end: 12.4V/12.4V)-----------
Coding: 0000002
Coding: 0021407
Coding: 0000011
Coding: 0000003
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 158235 km
Time Indication: 0
Date: 2017.11.13
Time: 21:54:56
Freeze Frame:
Temperature: 15.0°C
Coding: 0114123
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Coding: 0013878
Coding: 0012241
Coding: 2129203
Coding: 0082946
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 177
Mileage: 158232 km
Time Indication: 0
Date: 2017.11.13
Time: 21:54:50
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 158232 km
Time Indication: 0
Date: 2017.11.13
Time: 21:54:50
Cannot be reached
Coding: 0035563
Coding: 0423997
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 13:03:46
Freeze Frame:
Fault Priority: 3
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 14:18:24
Coding: 0000016
Coding: 0002014
Coding: 0035563
Revision: --H04---
Coding: 0005022
Coding: 0000016
Coding: 0000002
Coding: 0035370
Coding: 0062221
Coding: 0035370
Coding: 0010990
I just went through this again and I think that this confirms my suspicion. "Component Protection Active". A quick Google search tells me that I need to take this to the dealer :/
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 13:03:46
Freeze Frame:
Fault Priority: 3
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 14:18:24
000 - -
Freeze Frame:
Fault Priority: 2
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 13:03:46
Freeze Frame:
Fault Priority: 3
Reset counter: 176
Mileage: 142278 km
Time Indication: 0
Date: 2005.09.20
Time: 14:18:24
Samer Abbas
09-29-2017 06:30 AM
