LT: Is the Quattro system in a6 c6 fully mechanical? (Quattro retrofit on 2.0tdi)
Hello,
I want to make add quattro system to my a6 2.0tdi. (Why? Because why not) The parts are cheap, and i saw that a guy did it using the gerabox from a a4 b7 and the quattro system from a a6 3.0tdi. Doing my reaserch adding the mechanical parts isn't incredably hard. But I couldn't find any details on how the c6 quattro system works exactly, and I am not sure if there are any electronics controling it that I would need to add/change. Would appreciate any and all info.
[QUOTEj. Mukis;25772212]Hello,
I want to make add quattro system to my a6 2.0tdi. (Why? Because why not) The parts are cheap, and i saw that a guy did it using the gerabox from a a4 b7 and the quattro system from a a6 3.0tdi. Doing my reaserch adding the mechanical parts isn't incredably hard. But I couldn't find any details on how the c6 quattro system works exactly, and I am not sure if there are any electronics controling it that I would need to add/change. Would appreciate any and all info.[/QUOTE]
Hi!
I am going to quattro swap my 2.4, my best knowledge is the only electronic system what is different is the ESP, ABS.
If you have some specialist near might can help you working those.
Only if you are going with the manual gearbox, with the automatic it will be a lot electronic parts.
Hope i could help.
Hi!
Hope i could help.
AlteredEgo79
12-06-2018 09:05 AM
dcmetro
23
04-15-2010 12:04 PM
friend is leaning towards Passat over A6 - would someone pls tell me the diff b/t 4Motion & Quattro.
Silver Streakin'
08-16-2001 06:23 AM
