MMI and other TSB downloads <updated on 5/9/09>
#12
hmmm, I guess bumping has it's advatages. Thanks for all this information Pierre. I've used it to get the CD's which unfortunately haven't installed themselves yet. I guess I need to do that part too
#13
Cat Herder
this is actually the sticky feature, as I abuse my mod powers to further my own ends
muahahaaha!
p.s. yer welcome and good luck...patience and accuracy are key!
#14
You probably got water on the switch, just replace it. the switch is not that expensive, and the install is easy. I am talking from experience, it happened to me, only i had the problem when my windows were getting tinted and he dropped water on my switch.
#15
New to the Audi family, Hello ALL
<small>Thanks to Kevin Gary for some of these. I made a new thread to clear out the clutter. Any questions, email me or ask me in another thread to keep this one as clean as possible. Use the 'tt' link on the right to be notified of updates when viewing this forum.</small>
<b>These will get you an MMI update:</b>
<i>RVU - Repairing telephone preparation</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi%20telephone%20RVU.pdf">TSB# 2018510/3</a> <font color="red">NEW</font>
<i>BOSE Sound System without function, no sound</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-05.pdf">TSB# 2013107</a>
<i>Cursor is jumping in radio memory list</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-06.pdf">TSB# 2014281</a>
<i>MMI Surround setting lost (2006MY)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-08.pdf">TSB# 2013108</a>
<i>MMI Surround setting lost (2005MY)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-22.pdf">TSB# 2015136</a>
<i>Only one satellite radio station is displayed and playing with activated Tuner</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-11.pdf">TSB# 2014223</a>
<i>Navigation vehicle symbol jumps in map overview</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-09.pdf">TSB# 2014126</a>
<b>Got a CEL/MIL? Check these:</b>
<i>Poor Quality Gasoline</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.01-06-03.pdf">TSB# 01-06-03</a>
<i>MIL on (DTCs for misfire, P0300 - P0312) a.k.a. Bad Coilpacks</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.28-07-01.pdf">TSB# 2013623</a>
<i>MIL on - Bad G410 fuel pressure sensor</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.24-07-19.pdf">TSB# 2015106/3</a>
<i>MIL on - misfire DTC stored after cold start</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.01-07-02.pdf">TSB# 2011719</a>
<i>Cold engine runs rough or stumbles; warm engine may stall when engaging gear and vehicle is stationary</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.24-07-01.pdf">TSB# 2010890</a>
<i>MIL on (DTC P2106 18538) - ECM update</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.24-07-02.pdf">TSB# 2010878</a>
<b>Transmission:</b>
<i>No drive or delayed drive in "D" or "R" (DTC P1743/18151 may be stored in TCM)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.38-07-01.pdf">TSB# 2013280</a>
<i>Bucking when accelerating from a standstill</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.38-07-02.pdf">TSB# 2011722</a>
<i>Chirping, hooting, squeaking noise when shifting between 3-4</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.37-07-07.pdf">TSB# 2013023</a>
<b>Problems with your remote? Try these:</b>
<i>Engine intermittently or consistently does not start using advance key start button, starts w/ key & ignition switch</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.96-07-01.pdf">TSB# 2010941</a>
<i>Coming/leaving home function intermittently doesn't work when unlocking doors with the remote control</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.97-06-03.pdf">TSB# 2013709</a>
<b>Rattles & Creaks:</b>
<i>Trim Panels, Rattle (check your VIN!)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.70-05-02.pdf">TSB# A700502</a>
<i>A-Pillar and Roof Bar Make Cracking Noises</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.51-06-01.pdf">TSB# 2012964</a>
<i>Squeak or rattle noise in front door area or front sunroof area</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.50-07-01.pdf">TSB# 2014189</a>
<i>Trim for Tailgate Noisy</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.70-06-03.pdf">TSB# 2012960</a>
<b>Avant:</b>
<i>Tailgate inoperative at times</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.55-06-02.pdf">TSB# 2012698</a>
<i>Net partition noisy</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.68-06-05.pdf">TSB# 2013328</a>
<i>RVU - A6 Avant rear washer hose (IT)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.92-07-01.pdf">TSB# 2013391</a>
<i>Hose to rear washer jet leaking; Bose soundsystem, MMI, or navigation without function</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.92-06-01.pdf">TSB# 2013209</a>
<i>Luggage Cover is Noisy</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.68-06-04.pdf">TSB# 2012996</a>
<b>CVT:</b>
<i>MIL on, and/or Multitronic Transmission in Emergency Running Mode</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.37-07-10.pdf">TSB# 2012154</a>
<i>No drive or delayed drive in "D" or "R"</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.38-07-01.pdf">TSB# 2013280</a>
<b>Others:</b>
<i>RVU - Engine Control Module Update (I3) (4.2 Only)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.01-07-04.pdf">TSB# 2013535</a>
<i>Headlight range control warning is ON in driver information display. After cycling the ignition, warning symbol is OFF again</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.94-06-02.pdf">TSB# 2011041</a>
<i>Update Programming For Airbag Warning Light ON (II)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.69-06-05.pdf">TSB# 69-06-05</a>
<i>2005 Model Year Maintenance Schedule</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.2005.maintenance.sched.pdf"> Maintenance</a>
<i>Battery dead or low after returning to the vehicle</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.91-07-13.pdf">TSB# 2014127</a>
<i>RVU - Thumping, knocking or popping noise in fuel tank area (IH)</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.20-07-05.pdf">TSB# 2015111</a>
<i>Brakes squeal</i> : <a href="http://www.fileden.com/files/2007/3/13/883667/audi.tb.46-07-01.pdf">TSB# 2003273</a>
<b>Avant:</b>
<b>CVT:</b>
<b>Others:</b>
This is my very first Audi!! I am new to the Audi family; I just would like to know about installing updates. Do I need to purchase the CD's to install them? or find sites that I could download to my pc then rip them and use it the CD for the car. Still trying to figure out this great car; I usually do ALL of my maintenance with previous cars (honda and acura) but THIS car seems like a little bit difficult...but still learning. Just recently got the bently cd and vag-com.
ps. Do I need to change the transmission fluid, in this type of car? I've been getting different advise..1)don't need to cuz of transmission is sealed(lifetime) 2) yes, I do need to change it 60K miles...etc. Whats you guys take on it?? Thank you for you guys help in advance...I LOVE this car!!
Last edited by !staudi35; 03-27-2009 at 08:14 AM. Reason: needed to include signature
#16
Cat Herder
Hi and welcome.
1. try to get your dealer to do the MMI update. search the forum for ways to find your current version.
2. change your transmission fluid. most of us here feel that 'lifetime' really just means the length of the base warranty. if your dealer wont't do it, find a local indy that will and that has worked on C6s before. C5s use different fluids. ask your regional forum for good indy shops.
#17
Dont know if this is the right place to post but I heard there is a way to make it so your side view mirrors til down while reversing for parking. Is this a MMI update or a mod?
#18
need ur assitance please
Hi and welcome.
I've used vag-com to pull codes, when pulling codes I forgot turn-off daytime running lights. Next am, battery low indicator came on (10%), drove for 70 mi trying to recharge it, re-fill battery with distilled water and it is still 10% battery. Researched some the site (in regards to battery low 10%) and was advised to either 1) re-fill battery w/ distilled water or 2) software update for the battery level indicator ($125 at dealership). Is there any place/website to purchase these disks? Pls advise. I will also post my problem page on what I pulled on my car...there are alot of problem codes that came up. WOW!!I am over-whelmed right now.
ps. I am driving the car out of town, wondering if it is ok. I had hired someone to do my 55K maintenance;
these were done;
-change oil and oil filter (synthetic 10-30)
-replace air filter
-replace spark plugs (double platinum spark plugs)
All parts and labor= $360. I didn't have the time to do all so I just hired someone. I should have gotten a CPO Audi!
#19
Hello,
Great topic over here.
Very usefull !
Unfortunataley the link for "Navigation not available" displayed on MMI screen : TSB # 2016037 and Temperature different between front driver and passenger sides : TSB #2013883 doesn't seem to work.
Can somebody give me the correct link, because I am interested in the first one of these TSB's.
Thanks in advance
Very usefull !
Thanks in advance
#20
Hello Pierreb and Hello All;
these were done;
-replace air filter
these were done;
-replace air filter
