No crank
No crank
AudiWorld Team,
Please help me out!
I think I've hit my wall with my beloved 2008 A6 C6 @117k with VCDS logs/scans attached.
Over the weekend I finally finished the upper timing chain tensioners to fix the notorious startup rattle. The was my second time doing this work because initially my timing was off by a few degrees in bank 2. Anyways, this time I put everything back together and properly aligned the camshafts. Upon startup everything seemed great! The engine was running like new and VCDS was showing 0.0 / -0.1 degrees on cam adjusters for both banks, this confirmed timing was in check. I then proceed to pour some engine flush and get ready for the final oil change before daily driving again. I took the car for a 15 - 20 mile test drive into town and really felt the power and like new engine feel. Once I got back home and shut engine off that was the last of it. Now when I turn the key there is absolutely no response from the engine in terms of crank or turnover. All the electronics light up headlights, MMI, radio etc with the brand new charged battery however when I turn the ignition to start position nothing! I hear some faint clicking sounding like its coming from rear of car like the fuel pump is engaging but that's it. I didn't find anything in the VCDS scan that seemed out place.
If anyone has any ideas please advise.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Please help me out!
@Lagurdia - the log you shared is not your full VCDS log, just for your block 093 phases. Step one should be to clear all your faults and try again. But my guess is that you have a similar issue such as this: https://www.audiworld.com/forums/a6-...-home-2965548/
Try the following as well:
James98 - Fuses look fine and starter connections looked solid. Possibly a relay? But wouldn’t this come up in VCDS?
raj99 - Please see the txt attachment with VCDS logs. To follow up on your comments yes it is very similar to the forum post / video, however line item (05) Acc. Start Authorization seems to come up as a malfunction if the steering column module is defective. But yes I have cleared the codes several times with out any luck.
The log you attached does not contain the full log. It only contains the Block 092 and 093 measurements, it does not contain info pertinent to all the error msgs you have. You should re-upload the appropriate log.
not to sure if relay would come up in vcds there should be a relay for the starter I will find out what one it is. If you can’t see it your self just double check the starter is getting a main power and a signal power through ignition and a good earth should be through the block. Also if the clutch pedal sensor is faulty it wouldn’t let it start but would come up on dash please press clutch when you attempted to start it
Sunday,31,March,2019,12:21:17:25960
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
Ross-Tech: Home
VIN: WAUDH74F68N101377 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 53 55 56 61 62 65 72 77
VIN: WAUDH74F68N101377 Mileage: 188610km-117196miles
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 08214 444 178132
VCID: 313F17358D2F0C0F213-8064
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H04--- Serial number: 4413110
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 6597B365896790AF0DB-8030
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 6695B46974619BB7041-8032
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 42
Reset counter: 34
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:19
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x018C
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500981843
Coding: 0000003
Shop #: WSC 02323 785 00200
VCID: 6393AD7D8753EE9FE3F-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H46 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 C HW: 4E0 035 729
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 303A-087558699
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 2313ED7DC7D3AE9FA3F-8076
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000867044
Subsystem 3 - Serial number: 0118.09.070000000100010658ÿ
Subsystem 4 - Serial number: 010658ÿ
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 72
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.15
Time: 09:01:45
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000484046
Coding: 0524326
VCID: 1C61D681FAAD9167625-8048
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.15
Time: 09:09:04
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0012123
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 34
Mileage: 188600 km
Time Indication: 0
Date: 2007.02.16
Time: 04:36:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 270BF96DBFEB42BFFF7-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0230301
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F3B114D9B1B1AFF377-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 30
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:03:00
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0GBBL3
Coding: 0013902
VCID: 2A0D0059A0F97FD7E09-807E
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME373537470
Subsystem 3 - Serial number: 6342CSME33060A78%
Subsystem 4 - Serial number: 6352QSME4401517BA
Subsystem 5 - Serial number: 6362QSME407C0449I
Subsystem 6 - Serial number: 63734SME52183965/
Subsystem 7 - Serial number: 63834SME4D692F019
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025080030358
Coding: 0002041
VCID: 270BF96DB3EB42BFFF7-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:08
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 G
Component: KOMBIINSTR. M73 H20 0170
Revision: 00400000 Serial number: 5FG313547
Coding: 2065268
Shop #: WSC 03730 444 17936
3 Faults Found:
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:08
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:10
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:10
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0810282A3
Coding: E5D59E77703A0600
VCID: 2D070B45911768EF05B-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046007 Serial number: AUZ5ZBH3530126
VCID: 1869CA910E95FD4746D-804C
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 619FA7759D4FFC8FF13-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H51 0990
Revision: 00000000 Serial number: 395AW087508383
Shop #: WSC 02314 444 87987
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00-00000
Coding: 0035563
Shop #: WSC 02327 785 00200
VCID: 2C010641AA0D61E7125-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01090656130000
Coding: 4618269
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
6 Faults Found:
02742 - Bulb for Brake/Turn Signal Light; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 8
Reset counter: 71
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:03:45
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 133
Reset counter: 34
Mileage: 188234 km
Time Indication: 0
Date: 2007.01.13
Time: 15:39:40
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 63
Reset counter: 73
Mileage: 188234 km
Time Indication: 0
Date: 2007.01.13
Time: 15:41:02
02396 - Parking Light Rear Left (M4)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 73
Mileage: 188603 km
Time Indication: 0
Date: 2007.02.16
Time: 13:31:53
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 73
Mileage: 188603 km
Time Indication: 0
Date: 2007.02.16
Time: 13:31:53
02734 - Bulb for Tail Light 3; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 73
Mileage: 188603 km
Time Indication: 0
Date: 2007.02.16
Time: 13:31:53
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000066926
Coding: 0000016
VCID: 2517F365C9E750AFCDB-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000129505
Coding: 0002014
VCID: 5EE59C89AC31C377CC1-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 188612 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:00
Freeze Frame:
Voltage: 11.000 V
Temperature: 12.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00-00000
Coding: 0035563
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 17
Reset counter: 74
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:02:55
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 02145 785 00200
VCID: 2019E271D6C5B587BED-8074
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 188608 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:08
Freeze Frame:
Voltage: 10.14 V
Count: 247
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3FDB410D4B7BEA7FA77-806A
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394AY087850971
Coding: 0000002
VCID: 2E050C499C1113F73C1-807A
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.23
Time: 12:01:36
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000005783
Shop #: WSC 00000 384 00290
VCID: 2411EE61C2DDA9A7DA5-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2801151238
Coding: 344630393135313035442056413032383031313531323338
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:03:46
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.05
Time: 23:52:08
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.05
Time: 23:59:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:07
02275 - Quiescent Current Stage 4
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 118
Reset counter: 255
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.15
Time: 09:16:20
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0035370
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700063383
Coding: 0062221
VCID: 221DE879D8C9A797A89-8076
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005021299
Coding: 0010900
End-----(Elapsed Time: 01:52, VBatt start/end: 9.7V/9.7V. VIgn 9.7V)-------
Ross-Tech: Home
Coding: 0000002
Coding: 0020895
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 42
Reset counter: 34
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:19
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x018C
Hex Value: 0x00FF
Coding: 0000003
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 72
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.15
Time: 09:01:45
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.15
Time: 09:09:04
Coding: 0012123
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 34
Mileage: 188600 km
Time Indication: 0
Date: 2007.02.16
Time: 04:36:00
Revision: 00000000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 30
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:03:00
Coding: 0013902
Coding: 0002041
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:08
Coding: 2065268
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:10
Coding: 0082946
Revision: 00-00000
Coding: 0035563
Coding: 4618269
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 71
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:03:45
Freeze Frame:
Fault Priority: 3
Reset counter: 34
Mileage: 188234 km
Time Indication: 0
Date: 2007.01.13
Time: 15:39:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 63
Reset counter: 73
Mileage: 188234 km
Time Indication: 0
Date: 2007.01.13
Time: 15:41:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 73
Mileage: 188603 km
Time Indication: 0
Date: 2007.02.16
Time: 13:31:53
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 73
Mileage: 188603 km
Time Indication: 0
Date: 2007.02.16
Time: 13:31:53
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 73
Mileage: 188603 km
Time Indication: 0
Date: 2007.02.16
Time: 13:31:53
Coding: 0000016
Coding: 0002014
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 188612 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:00
Freeze Frame:
Voltage: 11.000 V
Temperature: 12.0°C
Revision: 00-00000
Coding: 0035563
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 74
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:02:55
Revision: --H04---
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 188608 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:08
Freeze Frame:
Voltage: 10.14 V
Count: 247
Coding: 0000003
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.23
Time: 12:01:36
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 188470 km
Time Indication: 0
Date: 2007.01.27
Time: 04:03:46
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.05
Time: 23:52:08
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.05
Time: 23:59:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 188615 km
Time Indication: 0
Date: 2006.11.24
Time: 03:47:07
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 188575 km
Time Indication: 0
Date: 2007.02.15
Time: 09:16:20
Coding: 0035370
Coding: 0062221
Coding: 0035370
Coding: 0010900
