CRC intake/turbo cleaner
Going to use CRC cleaner to help clean the intake. I’m not sure which vacuum line would be the best to use. I have a 2012 A7 3.0t. A picture of the line and it’s location would be helpful. Thanks in advance.
There's also a vacuum port on the firewall side of the intake tube just before the throttle body. You could pull off and cap the vacuum tube going to that port, and then spray the CRC cleaner into that open port. (You may need to add a short hose to that vacuum port to spray into, as it's pretty close to the firewall). You could also plug the port on the intake tube and spray into the vacuum hose. Either way will get the CRC cleaner into your engine.
The supercharger creates positive pressure.
How did the CRC work for you
HI - I have a 2012 A7. I keep getting an error message for secondary air (P0492) I'm wondering could I use this to clean the carbon. If anyone had results.
computrtutr
08-28-2008 01:15 PM
borden
12-03-2004 06:53 PM
