Hidden Features & Nuisances
Old Apr 6, 2012 | 04:09 PM
  #21
carljones11's Avatar
Originally Posted by aquarian
Yes, that will do it.
Old Apr 6, 2012 | 06:50 PM
  #22
tenspeed's Avatar
Originally Posted by Mickelin
So why do you want to turn it off completely?
I like to turn everything off when I park. All I want to hear on start up is the hum of the fuel pump followed by the starter motor. I listen for any new sounds before I start turning on fans and radios.
Old Apr 7, 2012 | 08:42 AM
  #23
ambarsaria's Avatar
On my A4, there was no way to "Pause" a song. You could mute but the song would go on. They fixed that in a future update, so I'm sure they will fix this too, but don't count on it this year.
Old Apr 7, 2012 | 06:25 PM
  #24
HipPop's Avatar
Default Yep, radio can be turned-off
Originally Posted by ambarsaria
You can press the power-button of the radio (volume control ****) and that will mute it. It's like turning it off. You can also press the volume control scroll-wheel at your steering wheel to do the same.
Yep, you can turn-off the radio all the way. To mute it, you press the button. To turn it off all the way, hold the button down for a bit longer. But the entire MMI system shuts when you do this.
Old Apr 7, 2012 | 06:37 PM
  #25
HipPop's Avatar
Default My two early annoyances....
Just wanted to share some things I observed:
Anyone else want to share cool little feature or annoyance bugs?
1. The heads-up display can be adjusted two ways. On the dash, there is a dial that lets the HEIGHT of the projection be tweaked. To change the BRIGHTNESS of the display, however, you have to go to the settings on the screen. Because I like to adjust the brightness depending on the daylight, I'd rather that have been attached to the on-dash dial so I can get to it on the fly. I don't need easy access to the height control. If the two had been swapped, that would have worked better for me.
2. I'd like to have an idle position for my side-view mirrors adjustment. When it is pointing to a side, I can bump it accidentally. When it is in heater position, it still shows on the energy consumer display even if too warm to be engaged.
Let me know if I'm over looking something
Old Apr 7, 2012 | 06:54 PM
  #26
viggense's Avatar
Just curious, the mirror defrost is not tied to the climate control system (or am I reading your post incorrectly)? I had a 9-3 and the mirror defrost was tied directly to the ACC, which activated based on atmospheric conditions and didn't require any special button to activate it. I take delivery in May but trying to learn as much as I can before doing so. Thanks.
Old Apr 7, 2012 | 09:13 PM
  #27
ambarsaria's Avatar
That's right!! Brightness is more suitable for that rotary dial... I don't ever change the height but do need to change the brightness. I wonder if you can hold the button and then turn... will have to try it tomorrow.
Old Apr 8, 2012 | 08:34 AM
  #28
fkaufman's Avatar
No, the radio can not be turned off. The whole MMI system can be turned off that way, which means the Bluetooth interface to the phone doesn't work either.
It is a most annoying design flaw!
Old Apr 8, 2012 | 08:35 AM
  #29
fkaufman's Avatar
It does not work that way.
Old Apr 8, 2012 | 08:40 AM
  #30
fkaufman's Avatar
The mirror heat is controlled by outside temperature, turns on and off automatically when it is cold enough. But the mirror direction switch must be in the center position. Another annoying design flaw. The heating to the mirror should not be cut off when the switch is in the left or right position, no good reason for it. My preference is to keep it in the right position, so the right mirror tilts down when the car goes into reverse. (My apologies to our friends in the UK and other right hand drive countries, plese reverse right and left in the previous statement).
