LED Headlights - Light Malfunction.
#31
Will do feralc. I've only got 22k on mine. The only other problems I have similar to yours are inconsistency with the MMI screen speed and the jerky tranny in the lower gears.
I've brought the tranny issues to my dealer in a prior visit and they told me there was nothing wrong so who knows. My warranty is up in May so may just take it to another dealer with that issue before then.
I will also check my statement on the headlight module, because if it shows it being a TSB for the 12 models, they should be able to take care of it before it arises.
#32
Just had my car in for rear brakes at 37K mi. Dealer automatically performed TCM update 37J1 which became available in early Dec. It appears to have fixed the jerky transmission problem at low speed. Also appears to eliminate the slight throttle hesitation. Time will tell.
In the past I've also replaced under warranty:
- Pass seat airbag sensor
- Headlight control module
- Pass and driver lumbar support mechanisms (clicking when pushing back on seat)
#33
#34
Glacier, no I didn't mention the transmission during this service. Had mentioned it in the past. I believe they're updating unsolicited as the cars come in for other services. (apparently just like the past steering update)
#35
#37
Alright feralc, just picked her up and luckily they did the TCM update without me asking. Definitely feel an improvement in the jerkiness in lower gears.
As far as the light module replacement out of warranty....$300 for the part plus about $190 in labor. There wasn't a TSB associated with it either, unfortunately.
Edit: Actually, the jerkiness issue only appears to have been resolved in D mode
#38
Ok so this interesting and concerning for me at least. It seems most of you have had a module in the actual headlight replaced....
FP-NUMBER: 4G0-907-472-C
DESCRIPTION: POWER MOD
My dealer replaced part 4G0-941-531-H, which is the actual dial you use to turn the lights from on, off, auto, etc. It's part #9 in the diagram in this link 2012 Audi A6 Quattro Parts - Audi Genuine Parts & Accessories eStore
#39
Lately this problem have occurred on mine too at random times when activating the low-beam led lights. Some days/weeks there are no issues, then the problem come back and disappears after short while. The lights still work when the warning shows up. Had the car for a scan, and it showed something wrong with the right side low-beam. Can it be the LED bulb that soon needs to be replaced, or is it a higher possibility that the control module is defective/damaged?
Anyone else had the same problem and want to share?
#40
Since the LEDs are still lit, I would hazard a guess that the problem lies in the ancillary equipment. LEDs loose brilliance over time, resisters, capacitors, etc. used in voltage regulation fail suddenly.
