18mm bolt for control arm!!! Cut or lower the sub frame, no way out!!!!
<center><img src="http://pictureposter.audiworld.com/61809/bolt18mm.jpg"></center><p>I don't even know if turning the bolt around will work either. Lowering the subframe may be the solution after all.
Hey!! I did it today...
Cut the bolt, it only took me 20 mins to replace the arm, easy.., I did take pics, but my camera battery went flat(10:30pm) will post tomorrow, but dont worry it is an esay job if you cut the bolt, and if you have a new bolt you can hammer the ball joint out..
good luck..
good luck..
Type_Audi
11
05-11-2010 05:12 AM
CK:1.8T+Rabbitâ„¢
03-19-2005 06:32 PM
Jon-1.8t
01-04-2005 09:56 PM
SteveJ_in_TX
09-07-2004 07:42 AM
