2001 S8 4.2 no heat
2001 S8 4.2 no heat
I have problem with blowing hot air to saloon and I wanna check the HVAC pump but how do remove it? Pump hides behind fresh air blower box (witch I alredy broke). Any ideas?
For what it is worth, I had issues with heat and had a few different people offer different solutions. At the end, my mechanic suggested getting the heater cores flushed and all started to work perfectly again.
I agree, start by
Checking the temp, is the coolant getting hot?
Bleed the air out of the system
Backflush the heater cores.
Maybe also check the coolant temp and any mixture flap stuff in the HVAC diags (google for this if need be, there is a diagnostic mode for the HVAC control head).
Check the center hot/cold wheel also, near the center vent in case that is confusing you.
I warm up engine for a bit and run for a test drive.
Temperature in dash rise up fine.
Then I check tubes and I notice that those pipes are ice cold:
Also I did VDCS test, no fault codes.
Well, i did check the hvac pump, everything seems work. I try connect those two pipes from last photo directly to one of the saloon radiators but no heat, feels like antifreez not even coming... No one is pumping liquid.
