A8 Rear Blind Motor
A8 Rear Blind Motor
Can anyone tell me how to access the rear blind motor? The blind is stuck in the up position and
when I try to lower it there is a GRINDING
Sound. It sound like a brocken gear tooth. Can the gear be changed or is a new motor needed?
This is what I found.....
<center><img src="http://pictureposter.audiworld.com/96961/16a_4d898057.jpg"></center><p>Hope this helps. Part number is 4D0 898 057.
Here is the procedure I found for the Drive disc for motor rear shade, replacing:
Power sunshade for rear glass removed.
Rear window shade motor removed .
Carefully drive rivets on drive gear to bottom using punch.
Install new drive disc with bolt, bearing washer and lock disc.
Component location: Flat position of gear points toward right side of vehicle.
NikkiDaddy
11
04-25-2008 10:03 AM
90/90Qs
12-10-2002 05:37 PM
BigMouse
10-15-2002 04:04 PM
