Sponsored by:
Sponsored by:
ac drain
Old 08-05-2018, 01:12 PM
profjobe's Avatar
Default ac drain
any body know where the ac drain tube is located as every time i make a sharp right turn my feet get wet thx
Old 08-05-2018, 01:41 PM
jfrahm's Avatar
audipages Unclogging the A8 Evaporator Drains
Old 08-06-2018, 05:20 AM
Y888's Avatar
cost me 344$ for a shop do clean all drains,suck out the water,they had to remove blower motor(200$ for that),i was getting water on my feet too plus motors that control ac flow were making noise but after they cleaned it it stopped.
Old 09-14-2018, 09:33 PM
Don't H8's Avatar
Default Ac drain location
The ac drain location is behind the console panel on the passenger side. All you need is a Phillips head screw driver. There's only one screw that holds it in. Once you've removed that panel youll see thick insulation foam under a wiring harness, lift the harness & remove the foam. You'll see a bright orange plug & it comes out easy. Anymore questions feel free to ask
Old 09-18-2018, 06:24 AM
spitanddirt's Avatar
+1
Only in my case, I used a borescope and a bit of patience to identify the drain below my blower motor where the leaves and other debris had blocked the hole. If I recall correctly, I used a set of "magic fingers" to get the thing unclogged. There was so much water, it was filling up the entire cavity around the blower motor and ECM box.
Old 09-23-2018, 08:49 AM
silverd2's Avatar
Actually there are two drains ... the same type on the driver's side too.
Any more corrections needed, feel free to ask :{)>
Old 10-07-2018, 05:40 AM
Photonica's Avatar
Default Audio designed a constricted area in the drain plugs
There is a portion of the two orange a/c drains that were designed to fail. That very small drain tube is far too small to be reliable. Slime can build up in this area and it will easily plug up. Thanks Audi, I am well aware of your stupidity. You do a 'half-a-job' and think you have accomplished something wonderful. Overall, Audi is not a very good choice for the money.
Old 10-14-2018, 01:57 PM
ratbag's Avatar
I always look forward to your responses.
regards, William, New Zealand.
MS1974
Q7 MK 1 Discussion
06-14-2018 10:04 AM
slamer
13
12-05-2015 11:34 AM
85urq
Quattro: Turbo / Ur / Sport
10-01-2005 02:17 AM
RidgeS4
04-20-2003 08:03 AM
DL
08-11-2001 11:53 PM
Quick Reply: ac drain
