A/C Question
Old Jul 1, 2005 | 10:48 AM
Biturbo5V's Avatar
Default A/C Question
My friend with an 01 A8L has water coming out the vents when the A/C is on. Primarily the floor vents but also the dash vents. The problem is exacerbated when driving uphill. His father-in-law (ex-mechanic) seems to think something is clogged along the A/C lines. Is this something we could fix ourselves? Is there a drainage plug somewhere in the system we could check?
Thanks,
Biturbo5V
Old Jul 1, 2005 | 11:07 AM
PaulW's Avatar
Default This will fix it
<ul><li><a href="http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html">http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html</a</li></ul>
Old Jul 1, 2005 | 01:59 PM
Jkay's Avatar
Default Common problem
What Paul said. Clear the evaporator coil drains and the cowl drains. They clog with goop.
Old Jul 1, 2005 | 03:43 PM
Biturbo5V's Avatar
Default Re: This will fix it
Thanks for the help guys. It is much appreciated.
Biturbo5V
Old Jul 3, 2005 | 04:27 AM
RonM's Avatar
New Member
Default A/C & Cowl Drains.
My 2001 A8L has the same drain problem. When you remove the orange drains from the sides of the transmission tunnel, you will notice that they have little squeezy rubber closing deals on the bottom of them. It appears that they require a certain amount of water to make them open. They are also great debris catchers. I took a pair of cutters and snipped the little closing lips off of them. This appears to be working well, I've noticed two nice puddles of water appear under the car every time I stop and my floor carpets are staying dry. You might want to have a bucket and a funnel ready the first time you remove the drains from the A/C sytem.
A8bil
Nov 9, 2008 09:51 AM
jazbo123
Apr 2, 2008 04:31 AM
Turbo_Anarchy
Jun 20, 2006 07:48 PM
quattro100
May 31, 2005 06:31 PM
SlehStar
Auto Detailing Discussion
Sep 27, 2002 04:25 AM
