Engine Control Module incorrect coding, need correct code!!
Old Oct 18, 2006 | 06:59 AM
spinedoc77's Avatar
Default Engine Control Module incorrect coding, need correct code!!
My independent mechanic pulled an engine code, I dont have the specific code but it was something along the lines of "Incorrect coding engine control module". He said it was a 5 digit code similar to the transmission code that was probably erased when the battery was disconnected.
Does anyone know what the correct 5 digit code is for the ECM in a 1997 Audi A8 4.2L ? Thanks much appreciated.
Old Oct 18, 2006 | 09:09 AM
PaulW's Avatar
Default Don't think you can recode the ECU, that's a factory thing
Post the codes, and as I mentioned, I have a spare 97 ECU that if you need for testing, I could probably help you out.
Old Oct 18, 2006 | 12:42 PM
spinedoc77's Avatar
Default Re: Don't think you can recode the ECU, that's a factory thing
Thanks Paul, much appreciated I may take you up on it. After searching a bit I am assuming my error code is P1612 ECM-incorrectly coded. I am only guessing that this is it, and will speak to my mechanic over the weekend to confirm.
My mechanic seems pretty confident that it can be changed.
I read in another post that the ECM code was 01273, does that sound right?
Old Oct 18, 2006 | 12:49 PM
marcodant's Avatar
Junior Member
I have the same issue but no issues with the car at all. I just got to the point of ignoring it
Old Oct 18, 2006 | 01:28 PM
tozoM8's Avatar
Tech Guru
Default Yes, that is the right code. Let me know how he recode the ECU.
I need to do it on mine.
ameth aguilar
Q5/SQ5 MKI (8R) Discussion
Oct 29, 2018 11:26 PM
hellonwheels33
10
Jun 15, 2016 09:49 PM
AudiQmann
Mar 22, 2006 05:42 PM
WJM
VAG-COM Discussion
May 21, 2003 09:42 AM
GMikes97A8Q
Jan 4, 2003 09:22 PM
