heating issues (please read its cold in AK)
My heater fan worked for a couple of minutes then stopped abruptly every time I started the car last week. Now it does work at all that I can see. Brother suggested fans, friend suggested heater motor was crapping out. I took it into a semi-warm garage for about 4 hours to let it thaw out and to investigate the fans. I didn't get far...
I really need some input, its generally below 25 degrees right now, dipping below 0 at night...It's horrible.
But thank god for heated seats.
Thanks in advance,
Daniel B.
Thanks in advance,
Daniel B.
Is it the original fan? If so....probably needs replacement
There is a lot more to troubleshooting, I would follow the procedure on audipages and see if there is power at the connector if you really want to troubleshoot it.
Does the engine warm up?
I think this is what PaulW means.
<ul><li><a href="http://www.audipages.com/Tech_Articles/heatac/fanreplace.html">http://www.audipages.com/Tech_Articles/heatac/fanreplace.html</a</li></ul>
Sounds like you may need a new fan motor
How to tell?
Well, with the blower motor removed, the brushes will be worn to stubs, and the armature will be "grooved". But by then, putting in a new motor will seem justified. It takes a bit over an hour to do the job if you have a good assortment of 1/4inch drive extensions and stubby screw drivers ;-)
Whenb I repalced mine, I thought the job was a real pain while doing it, but after it was completed. "That was not so bad" ;-)
Heat in winter is a VERY nice thing.
EBG 18T [Eric]
12-09-2006 10:09 AM
Randolph
01-24-2006 11:39 AM
85-4kq-girl
11-09-2004 03:18 PM
Brdman*
Audi 100 / A6 (C4 Platform)
01-26-2004 11:47 AM
