Mirror failure
Old Sep 5, 2013 | 11:13 AM
dreamhope's Avatar
Default Mirror failure
Hello,
I just bought a D2 4.2 Q w/ 98000 kms. Everything else works, but the mirrors don't (cannot adjust or fold away). (Only manual adjustment is possible.) My guess is that a chip is gone (otherwise it's unlikely that all functions in both mirrors fail).
Is this going to be a costly repair? Should I visit a dealer?
I live in the Paris region but can visit Germany easily (got the car from Germany).
Thanks
Old Sep 5, 2013 | 05:06 PM
silverd2's Avatar
Originally Posted by dreamhope
Hello,
Thanks
Year of car?
Have you checked fuses...2000 (Euro 99) and later, #2 on the 5th row (brown row).
Anything else not working?
Old Sep 6, 2013 | 01:52 AM
dreamhope's Avatar
Originally Posted by silverd2
Year of car?
Thanks. It's 1997. Everything else works. You're right. I should check the fuses. Do you have a link to a picture of the layout?
Thanks again.
Old Sep 6, 2013 | 06:37 AM
silverd2's Avatar
Thanks again.
Assuming that your car is LHD, the fuse box is next to the front passenger's right foot with a twist off **** holding it there...the fuse diagram is on the inside of that cover.
But, I believe the same fuse powers other accessories, so your problem may not be the fuse...I'd check it anyway.
The problem could also be either the switch itself (or wiring to it) or the control module (relay), which is in central electrics, under the passenger's foot panel. Inside that panel, is a relay box in the center which pulls out partially...the module is the large relay at top left of that panel.
If you look in there, check for evidence of water intrusion...this sometimes happens due to clogged inside AC evaporator drains or outside fresh air plenum rain drains or both.
Old Sep 6, 2013 | 09:01 AM
dreamhope's Avatar
Fixed it! Thanks a lot!
It's the 2nd brown fuse, 10A. On the manual it says it also serves seat memory, which explains why I can't set the seat memory yesterday (thought I did it wrong, but apparently it's the fuse).
Old Mar 19, 2021 | 04:28 PM
ctxspy's Avatar
Epic thread resurrection -- Just wanted to say, I just had this same issue, 10a fuse in brown row, says it controls mirror switch functionality (among other things). I had already previously taken apart my mirror switch needlessly, and i hope this helps someone else in the same situation.
To recap, my symptoms were:
1) Mirrors could not be adjusted using mirror switch control on the door
2) Mirrors COULD be adjusted by virtue of selecting a seat memory position
3) Passenger mirror DID dip when shifting into and out of reverse
Thanks to you guys for posting the above, as long ago as it was!
ECS Tuning-Audi
S4 (B8 Platform) Discussion
Jul 26, 2018 02:02 PM
Kerry G
May 18, 2018 06:12 AM
ECS Tuning-Audi
Feb 4, 2016 08:36 AM
2furious
Q7 MK 1 Discussion
Sep 30, 2015 10:48 AM
jonedwd
Audi A3 / S3 / RS 3 MKII
Sep 26, 2015 10:49 PM
