Old bolts won't die? Trouble with the shock replacement...
So I have the A8 up on jackstands and I'm following the procedure <a href="https://www.audiworld.com/tech/wheel28.shtml">here</a>.
I have the nut off the bolt that holds the top set of control arms arm, but the bolt won't budget. I put some WD40/losener spray stuff on it, let it sit, applied a second dose a few hours later, and it still won't budge. Any ideas how to get it out? I have some nice Bilstiens here and they're ready to go.
correct that bolt can stay. Here's what I do:
1) disconnect the sway bar (2) 13mm each side
2) take out the back bolt on the lower straight arm and push down. You can leave the balljoint connected.
You should now have enough room to get the strut out.
Bob
Bob
