Transmission acting up
I would recommend you go to an independent mechanic and have the codes pulled. I don't suppose you are in the Chicago area?
Limp mode can be triggered by many things that are NOT internal trans problems...water in the E-box, where TCM is located (fresh air plenum) or other electrical connections and related systems...or even low on atf, which should be indicated by a visible leak under the car...trans's don't "use up" fluid. If atf is low, it has to leak somewhere, even at radiator where atf cooler is integrated.
Limp mode (all gears lit on instrument cluster) is the car's way of protecting the trans when it senses a problem...it's one forward gear, 3rd or 4th(?). That's why the slippage feel, but it will get you home...you should have reverse also (standard with limp mode). Sometimes it will reset to normal when you shut the car off and restart...or even disconnect battery and reconnect...but "something" triggered it and will likely do so again.
Before doing anything else, join and post at http://forums.quattroworld.com/a8/ ...there are a couple of regular members there from your area and will likely know a dependable mechanic in the area to check your car out...better than an Audi dealer. A good mechanic will have Vagcom diagnostic program, to read codes for the trans...a simple code read at Advance or Autozone is not good enough.
Thanks,
Burgie
A bad battery caused the trans in a '06 VW Passat I had to go into limp mode. Restarting the car usually cleared it. Sounds very familiar...
