upper control arms
Old Jun 9, 2005 | 04:23 AM
-OvO-'s Avatar
Default upper control arms
at one end, there's a big rubber bushing. At the other end, there's some kind of joint covered by a rubber boot. What's under there? Or is that just a little bushing?
How do you know if the control arm bushings need to be replaced? One of mine has a visible crack in it.
Old Jun 9, 2005 | 04:33 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default Re: How do you know if the control arm bushings need to be replaced?
Are you getting a "clunking" in your front suspension? Say when going over bumps and/or when turning?
And typically the entire control arm is replaced, not just the bushings. I haven't seen bushing replacement kits out there, though they may exist.
Old Jun 9, 2005 | 04:44 AM
-OvO-'s Avatar
Default no clunking that I've noticed
Bentley's has a procedure for replacing the bushing. It seems silly to replace the hunk of cast aluminum, but maybe they're remanufactured?
Old Jun 9, 2005 | 05:34 AM
theraudi1's Avatar
Default bushings for control arms...
stand alone bushings can be found at www.etyparts.com under "online catalog". I'm guessing that you're gonna need access to a press for these but great way 2 save $$$$.
theraudi1
'98 A8 4.2
'04 Passat V6 4-motion (wife's ride)
'87 Scirocco 8v
jaxAR
Audi allroad
Dec 15, 2008 07:43 PM
boonies
Nov 13, 2008 05:09 PM
mplman
Jun 10, 2005 01:43 PM
PsychoS4
Dec 15, 2003 05:07 PM
audimods
Aug 28, 2002 11:42 AM
