Sponsored by:
Sponsored by:
'07 A8 thermostast replacement
Old 01-16-2014, 07:18 AM
Gary Knox's Avatar
Default '07 A8 4.2 thermostast replacement
Anyone here ever replaced the thermostat on the timing chain A8 4.2 engine? I 'think' ours may be stuck open, as it took about 4 miles for the engine to reach operating temperature this morning (29 F ambient).
IF you have, and can give guidance, I'd appreciate it VERY much.
Thanks,
Gary Knox
Old 01-16-2014, 01:16 PM
krazzz's Avatar
That doesn't seem too out of line for the ambient temperature. Are you used to this kind of temperature or is this new to you? I replaced the thermostat in mine ('04) about a month ago and it takes 4-8 miles to reach full operating temperature this time of year. I don't know of a single V-8 engine that would do it any sooner than that. Now a small displacement 4 cylinder should reach full operating temperature by then but I would not expect a large V8 to do the same. As long as you are at full temp in less than 10 min and your heater is blowing hot air I think your thermostat is working fine.
Old 01-16-2014, 01:21 PM
krazzz's Avatar
Today it was only 14 degrees here and my car was only at the 1/4 mark on the temp gauge after a 2 min warm up and a 3 mile drive to work.
Old 01-17-2014, 05:24 AM
Gary Knox's Avatar
That ambient temp was higher than we've had for many days this January (down to 2 degrees one morning). For the previous travel this winter, the temp needle has been off the peg within about 1/4 mile, and has been to full operating temp (needle vertical) within about 1 1/2 miles. Just seemed particularly slow yesterday!
I'll monitor it for a few days before I decide whether a thermostatectomy is required.
Gary-
Old 01-17-2014, 05:32 AM
PaulW's Avatar
Get a V10.....it takes a while for my car to come up to temperature....usually 5-10 miles on a 15F degree day.
Old 01-17-2014, 05:38 AM
krazzz's Avatar
Do you park in a garage at night? To get the needle moving in a 1/4 mile is pretty amazing to me. I park outside and while I've never measured the distance before I would say it takes at least a mile to get mine moving and it is never at full temp by the time I reach work 3 miles away. Even in the summer time none of my vehicles have reached full operating temperature by the time I get to work (of course I only drive V8s.) Driving conditions would play a lot into this though. If you have a lot of traffic and stop and go driving you would warm up in much less distance than me. I have only one stop and I the speed limit is 35 the whole way. I'll keep an eye on mine tomorrow and try and get a feel for the time an distance. I will say that I do not think your thermostat is bad if you can get up to temp that quickly. My mother-in-laws thermostat went out on her minivan a month ago and she could drive 15 miles in to our house and it would never reach operating temp.
Old 01-17-2014, 06:27 AM
Mike141's Avatar
My 05 will take about 7-10 minutes of driving for needle to move in winter. I think your thermostat is fine, that does not seem excessive especially when it's below freezing.
Old 01-17-2014, 09:02 AM
Gary Knox's Avatar
I do park in the garage overnight. Temperature of the engine/car when leaving is usually in the 40 degree range when outside temp is about 20 F.
Just gonna' monitor for a while. Thanks for the input on you'all's experience.
Gary-
Old 01-17-2014, 09:35 AM
krazzz's Avatar
I figured you parked in the garage because there is no way your car would heat up that fast if you had it parked outside. I can say for sure that your thermostat is working 100% and you have nothing to worry about.
Old 01-21-2014, 08:51 AM
that_tg's Avatar
Default How do you change the thermostat?
Has anyone done it? I need to change mine. If I can find it on AllData I will share the process.
Quick Reply: '07 A8 thermostast replacement
