2004 A8L - How to clear 02596 Rear Brake Pads Worn Fault?
Gentlemen,
How do I successfully reset the 02596 Rear Brake Pads Worn Fault from the dashboard? I followed below thread and VCDS video to the letter.
https://www.audiworld.com/forums/a8-...ience-2846250/
VCDS says for older A8 models I may have to do several adaptations and functions tests to clear the code, I have done it 10 times with no success. For the record, pads and rotors were purchased from local audi dealer, and charger was always connected.
Your expertise is greatly appreciated!
Forgot to mention, the implausible signal fault, cleared during first attempt, only the brake pads worn faults stayed and the 12 mm pad thickness is stored in Adaptation.
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 91590 999 80175
VCID: 1D319C4DC4E882AC13-8048
2 Faults Found:
02596 - Rear Brake Pads Worn
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 253
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:17
Freeze Frame:
Voltage: 12.01 V
Count: 60
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:16
Freeze Frame:
Voltage: 11.39 V
Count: 61
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:17
Freeze Frame:
Voltage: 12.01 V
Count: 60
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:16
Freeze Frame:
Voltage: 11.39 V
Count: 61
Did you close the controller and turn the ignition off, as it says just above the pictures about replacing pads? As in, as if you went to replace the pads even though you aren't now? Having BTDT, it is even easier to miss that step when you are just trying to reset it, and think that like everything else in VCDS you just press ahead with no need to close out the item/session. ...BTDT...
Your PCode Indicates Pad Thickness Not Adapted
Gentlemen,
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:17
Freeze Frame:
Voltage: 12.01 V
Count: 60
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:16
Freeze Frame:
Voltage: 11.39 V
Count: 61
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:17
Freeze Frame:
Voltage: 12.01 V
Count: 60
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 119
Mileage: 118480 km
Time Indication: 0
Date: 2018.04.09
Time: 12:53:16
Freeze Frame:
Voltage: 11.39 V
Count: 61
Connect a battery charger as per repair manual.
[53 - Parking Brake]
[Adaptation – 10]
Enter Channel 06
[Read]
Enter pad thickness in New Value
[TEST]
[Save]
Confirm Yes.
[Done, Go Back]
[Basic Settings - 04]
Group 010
[Go!]
The brake pads are now opening and closing 3 times.
Motor AMP load increases then drops to near zero.
Basic Settings: ON
Wait thirty seconds!
[Done, Go Back]
[Fault Codes - 02]
[Clear Codes - 05]
Confirm Yes.
[Close Controller, Go Back - 06]
I also found this on VCDS website Audi A8 (4E) Parking Brake - Ross-Tech Wiki
- When 02596 - Rear Brake Pads Worn is stored after the pad thickness is adapted, try:
- Repeating the Function Test Basic Settings operation and make sure the stored value in Adaptation channel 006 did not resort back to 03. If that alone does not resolve the issue proceed to 2:
- Test drive the vehicle and scan it to see if 02596 - Rear Brake Pads Worn switched to Intermittent, allowing you to clear it.
Are you SURE you adapted and it took? What is the content of channel 6 now? Like this:
[Adaptation – 10]
Enter Channel 06
[Read]
[TEST]
[Save]
Confirm Yes.
[Done, Go Back]
Group 010
[Go!]
Basic Settings: ON
[Done, Go Back]
[Fault Codes - 02]
[Clear Codes - 05]
Confirm Yes.
[Adaptation – 10]
Enter Channel 06
[Read]
[TEST]
[Save]
Confirm Yes.
[Done, Go Back]
Group 010
[Go!]
Basic Settings: ON
[Done, Go Back]
[Fault Codes - 02]
[Clear Codes - 05]
Confirm Yes.
Yes I did close the controller and took the key out of ignition prior to replacing the pads. I was following VCDS video instruction to the letter. The 12 mm pad thickness in Adaptation also is there whenever I check. I took it for a short drive to bed in the pads and rotors this morning.
Hmm, Ross Says the Pad Thickness Range is 3-14
1. As you have done, set the 12mm or 11 whatever, then make sure that is stored in there.
2. Clear codes
2. Drive it. - will fix itself after a bit. At least mine did.
Flakiest POS module ever!
2. Clear codes
Thank you everyone for support. I tried few more times parking brake on and off then went to the adaptation channel 06 followed by function test 010 in basic settings 04 using different pad thicknesses. Started wth 10,11,12,13, and then finally the worn rear brakes fault disappeared from dash when I used 14 mm setting in adaptation. I was then able to clear fault in 53 parking brake module. Test drove and tested parking brake all seems good fault is gone. I then went back to adaptation 06 and changed pad thickness back to 12. As soon as I did that fault came back and I wasn’t able to reset which is back to initial symptom. I repeated all above with 14 mm pad thickness and function test and fault is gone and cleared again. Hopefully I can call it done. Thanks again
PSG (03-25-2020)
DutchDoofus
9
09-05-2008 11:28 AM
JoeO
06-20-2003 06:29 PM
Bryce
11-05-2001 09:32 PM
