2006 Audi a8 suspension... Weird
This car has been very nice to me untill I lifted it up with the factory jack and while I had it up the Jack broke and the car fell down a little without tire on it landed in dirt. After putting wheel back on the front suspension is all the way to the ground and the rear is normal... The pump pumps and never tried to fill the front... Scanned with a vcds haven't before but4 codes for suspension came up... did go thru and sprayed soap on front bags and lines and block never saw any bubbles.
01400 002 lower limit exceeded
01580 leak in system
01400 001 upper limit exceeded
01772 signal from level control pressure sensor (G291) 008 implausible signal
Any thoughts or advice is grateful
Factory jacks are lethal.....lifting the car in the dirt is lethal....
Your code is telling you that you have a leak. Clear codes and check again.
Compressor should lift car even with a leak. If it doesn't, your compressor is shot. Can you hear the compressor?
These guys have replacement shocks...Rebuild Master Tech Air Suspension, Engine Parts & More...
Warren Stills
14
03-19-2019 04:07 PM
tt1234
02-02-2019 07:03 PM
benpitt
169
12-09-2018 11:52 AM
faciest
01-15-2017 09:38 PM
