Sponsored by:
Sponsored by:
ABS ESP Bosch 5.7 unit - can I replace?
Old 07-23-2014, 12:49 PM
  #11
mishar's Avatar
There are two steering angle sensors and they have different plugs. They are prone to be defective, but you should get VCDS faulty code about that. On dashboard you should have ESP yellow warning too.
To get deeper into ABS module programming you need Access Code and I am not aware that it is available.
Old 07-23-2014, 01:40 PM
  #12
Knightey-'s Avatar
On dashboard I have ESP yellow warning, but this is mistake from ABS ESP UNIT, becase this unit isn't coded.
So I cannot use the newer steering angle sensor?
If they have different plugs, they must have a different connection, so this is the reason why newer ABS unit don't communicate with this older steering sensor.
Do you think, that I can found some diagram of these steering angle sensors? I want to know differences.
I know about this programming with ABS, I did it by manual from Ross-Tech ->
Old 07-23-2014, 05:04 PM
  #13
mishar's Avatar
Have you checked all faulty codes? Is Steering Angle Sensor one of them? Faulty sensor would give you problems with coding.
I don't know if sensors with different connection harnesses are different in any other way (I believe not), but you can't connect the wrong one.
Old 07-23-2014, 10:54 PM
  #14
Knightey-'s Avatar
Yes I did. I have many mistakes because this ABS unit, but with this sensor nothing.
Where excatly shoulb be a mistake for this steering angle sensor?
In ABS unit? Motor unit? Somewhere else?
Old 07-23-2014, 11:27 PM
  #15
mishar's Avatar
I have to check tomorrow on my car but I think it will come under Steering Wheel Electronics and under some others too. If you use applications > Installed List you will get all faulty codes.
Old 07-24-2014, 11:35 AM
  #16
Knightey-'s Avatar
Here I made for you the complet list of errors from my car, after I erased all faults, which can be deleted.
Čtvrtek,24,Červenec,2014,19:57:58:42825
VCDS -- Windows VAG/VAS Emulator
VCDS verze: SVO 12.12.2.0
Verze dat: 20131014
Jméno servisu: Kabele
Číslo dílny: 000 12345 000000
VIN: WAUZZZ4E04N003347 Výrobní štítek:
Kilometry: 182250km Číslo zakázky:: A8D3_newABS
Model: 4E (4E0)
Sken: 01 02 03 05 06 07 08 09 15 16 17 19 1D 1E 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUZZZ4E04N003347 Kilometry: 182250km
00-Snímač úhlu rízení -- stav: OK 0000
01-Motor -- stav: OK 0000
02-Aut. převodovka -- stav: OK 0000
03-ABS brzdy -- stav: Nefunkční 0010
05-Oprávnění startu -- stav: OK 0000
06-Paměť sedadla S -- stav: Nefunkční 0010
07-Zobraz. jednotka -- stav: OK 0000
08-Klima/topení -- stav: OK 0000
09-Centrální elektrika -- stav: Nefunkční 0010
15-Airbagy -- stav: OK 0000
16-Elektronika volantu -- stav: OK 0000
17-Přístrojová deska -- stav: OK 0000
19-CAN Gateway -- stav: OK 0000
1D-Identifikace řidiče -- stav: OK 0000
1E-Media Player 2 -- stav: OK 0000
25-Imobilizér -- stav: OK 0000
34-Řízení výšky -- stav: Nefunkční 0010
36-Paměť sedadla Ř -- stav: Nefunkční 0010
37-Navigace -- stav: OK 0000
38-Elektronika střechy -- stav: Nefunkční 0010
42-El. dveří řidiče -- stav: OK 0000
46-Komfort systém -- stav: OK 0000
47-Audio soustava -- stav: Nefunkční 0010
4F-Centrální elektrika II -- stav: Nefunkční 0010
52-El. PP dveří -- stav: OK 0000
53-Parkovací brzda -- stav: OK 0000
55-Reg.sklonu Xenonů -- stav: OK 0000
56-Rádio -- stav: OK 0000
61-Regulace baterie -- stav: OK 0000
62-El.LZ dveří -- stav: Nefunkční 0010
65-Hlídání tlaku v pneu -- stav: OK 0000
67-Řízení řeči -- stav: OK 0000
72-El.PZ dveří -- stav: OK 0000
76-Park. pomocník -- stav: OK 0000
77-Telefon -- stav: OK 0000
Adresa 01: Motor Labely: User\077-910-560-BFM.clb
Řídící jednotka SW: 4E0 910 560 E HW: 4E0 907 560
Díl: 4.2L V8/5V G 0040
Revize: 00000000 Seriové číslo: AUX3Z0C4314972
Kódování: 0011773
Dílna #: WSC 29238 401 83621
VCID: 23438BB5E272B106A65-8076
Nenalezena žádná chyba.
Readiness: 0110 1101
Adresa 02: Aut. převodovka Labely: 09E-927-156.lbl
Řídící jednotka SW: 4E0 910 156 E HW: 09E 927 156 A
Díl: AG6 09E 4,2l5V RdW 0070
Revize: 00000001 Seriové číslo: 0013349
Kódování: 0000001
Dílna #: WSC 02313 785 00200
VCID: 244188A9E77CB63EDFF-8071
Adresa 03: ABS brzdy Labely: User\4E0-910-517.clb
Řídící jednotka SW: 4E0 910 517 B HW: 4E0 614 517 BC
Díl: ESP 5.7 allrad H46 0510
Kódování: 0000000
Dílna #: WSC 00000 000 00000
VCID: 224D8EB1FD68B80EAD3-8077
2 závad nalezeno.
01044 - ridici jednotka chybne kodovana
000 - -
00778 - snimac uhlu rizeni (G85)
005 - zadne; nebo spatne zakladni nastaveni / prizpusobeni
Adresa 05: Oprávnění startu Labely: 4E0-910-131.lbl
Řídící jednotka SW: 4E0 910 131 HW: 4E0 909 131 C
Díl: FBS AUDID3 H02 0120
Revize: 01203602 Seriové číslo: AUX3Z0C4314972
Kódování: 0409600
Dílna #: WSC 02311 785 00200
VCID: D8B96C596BB4A2DE037-808D
Subsystém 1 - Řídící jednotka: XXXXXXXXXXX
Díl: ELV XXXX
1 nalezena chyba:
00181 - autorizacni antena pristupu/startu (v zadnim narazniku) (R136)
011 - Preruseni
info o závadě:
Stav závad: 01101011
Priorita závad: 4
Frekvence závad: 0
Počítadlo resetů: 38
Kilometry: 182256 km
Indikace času: 0
Datum: 2003.10.08
Čas: 00:40:10
Adresa 06: Paměť sedadla S Labely: nevybrány
Řídící jednotka SW: 4E0 910 760 C HW: 4E0 959 760
Díl: Sitzmemory BFS H06 0060
Revize: 00000000 Seriové číslo: 5DS 008 795-03
Kódování: 4063328
Dílna #: WSC 00000 785 00200
1 nalezena chyba:
01721 - snimac vyskoveho staveni sedadla spolujezdce: vzadu (G280)
010 - preruseni / zkrat na plus
info o závadě:
Stav závad: 01101010
Priorita závad: 4
Frekvence závad: 7
Kilometry: 0 km
Indikace času: 0
Datum: 2003.01.01
Čas: 00:00:00
Adresa 07: Zobraz. jednotka Labely: 4E0-910-7xx-07.lbl
Řídící jednotka SW: 4E0 910 769 D HW: 4E0 035 729
Díl: Interfacebox H43 5150
Revize: 00000000 Seriové číslo: 343EL037517083
Kódování: 0010002
VCID: 2D576D8DB4B67776001-8078
Subsystém 1 - Řídící jednotka: 4E0 910 609
Díl: Bedienteil MMI H41 0010
Subsystém 2 - Seriové číslo: 317EG037511704
Subsystém 3 - Seriové číslo: ˙˙22.05.03˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙
Subsystém 4 - Seriové číslo: ˙˙˙˙˙˙˙
Adresa 08: Klima/topení Labely: nevybrány
Řídící jednotka SW: 4E0 910 043 HW: 4E0 820 043 A
Díl: KLIMAAUTOMAT 015 0240
Revize: 00000017 Seriové číslo: 00000000017243
Kódování: 0004201
VCID: DABD765115B8B0CE353-808F
1 nalezena chyba:
01206 - signal pro casove rozpeti zapalovani - VYP
014 - defekt
Adresa 09: Centrální elektrika Labely: 4E0-910-279.lbl
Řídící jednotka SW: 4E0 910 279 E HW: 4E0 907 279 E
Díl: ILM Fahrer H11 0100
Kódování: 0011111
Dílna #: WSC 27162 401 66366
VCID: 2A5D66918558604EE53-807F
Subsystém 1 - Řídící jednotka: 4E1 910 113 B
Díl: Wischer WWS D3 H50 0400
Kódování: 00000036
Dílna #: WSC 27162
2 závad nalezeno.
01495 - zarovka dalkoveho svetlometu vlevo (M30)
info o závadě:
Priorita závad: 2
Frekvence závad: 1
Kilometry: 182258 km
Indikace času: 0
Datum: 2003.10.08
Čas: 00:17:09
01499 - zarovka dalkoveho svetlometu vpravo (M32)
info o závadě:
Priorita závad: 2
Frekvence závad: 1
Indikace času: 0
Datum: 2003.10.08
Čas: 00:17:09
Adresa 15: Airbagy Labely: 4E0-910-655-84.lbl
Řídící jednotka SW: 4E0 910 655 HW: 4E0 959 655
Díl: Airbag 8.4E+ H08 0940
Kódování: 0430707
VCID: E3C34BB522F27106665-80B6
Adresa 16: Elektronika volantu Labely: 4E0-910-549.lbl
Řídící jednotka SW: 4E0 910 549 HW: 4E0 953 549
Díl: Lenksäulenmodul H09 0030
Kódování: 0012141
VCID: E5C755AD2CC60F36881-80B0
Díl: Lenkradmodul H02 0050
Adresa 17: Přístrojová deska Labely: 4E0-910-xxx-17.lbl
Řídící jednotka SW: 4E0 910 900 HW: 4E0 920 900 EX
Díl: KOMBIINSTR. VDO H55 0090
Revize: D25 Seriové číslo: AUDID3I8100087
Kódování: 0000003
VCID: DCB170491F8C4EFE27F-8089
Adresa 19: CAN Gateway Labely: 4E0-910-468.lbl
Řídící jednotka SW: 4E0 910 468 HW: 4E0 907 468 A
Díl: Gateway H07 0050
Revize: 07 Seriové číslo: 110030352701F4
Kódování: FCFF7BDD2B7104
Dílna #: WSC 00000 128 00289
Adresa 1D: Identifikace řidiče Labely: 4E0-910-218.lbl
Řídící jednotka SW: 4E0 910 218 HW: 4E1 905 218
Díl: FPI_1 H04 0060
Revize: 06000104 Seriové číslo: 20052003163113
VCID: DEB57A4109905CEE49B-808B
Adresa 1E: Media Player 2 Labely: 4E0-910-111.lbl
Řídící jednotka SW: 4E0 910 111 F HW: 4E0 035 111
Díl: CD-Changer H43 0470
Seriové číslo: AUZ5ZBC1016247
VCID: 1C31B049DF0C8EFE67F-8049
Adresa 25: Imobilizér Labely: 4E0-910-131.lbl
Kódování: 0409600
Díl: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 nalezena chyba:
011 - Preruseni
info o závadě:
Priorita závad: 4
Frekvence závad: 0
Indikace času: 0
Datum: 2003.10.08
Čas: 00:40:10
Adresa 34: Řízení výšky Labely: 4E0-910-553.lbl
Řídící jednotka SW: 4E0 910 553 F HW: 4E0 907 553 E
Díl: LUFTFDR.-CDC H05 6260
Kódování: 0011110
VCID: 264592A19140442EC1B-8073
2 závad nalezeno.
01575 - regulace vypnuta
000 - -
info o závadě:
Stav závad: 11100000
Priorita závad: 4
Frekvence závad: 1
Indikace času: 0
Datum: 2003.10.08
Čas: 00:36:44
008 - neverohodny signal
info o závadě:
Stav závad: 11101000
Priorita závad: 3
Frekvence závad: 1
Indikace času: 0
Datum: 2003.10.08
Čas: 00:36:44
Adresa 36: Paměť sedadla Ř Labely: nevybrány
Díl: Sitzmemory FS H06 0060
Kódování: 4063342
1 nalezena chyba:
01445 - snimac podelneho nastaveni sedadla ridice (G227)
info o závadě:
Priorita závad: 4
Frekvence závad: 1
Kilometry: 119080 km
Indikace času: 0
Datum: 2010.03.12
Čas: 02:39:51
Adresa 37: Navigace Labely: 4E0-910-88x-37.lbl
Řídící jednotka SW: 4E0 910 888 P HW: 4E0 919 887 C
Díl: MNS ECE H41 1060
Revize: 00000000 Seriové číslo: 305EC037534131
VCID: 3B7353D57AC2E9C68E5-806E
Adresa 38: Elektronika střechy Labely: 4E0-910-135.lbl
Řídící jednotka SW: 4E0 910 135 A HW: 4E0 907 135 A
Díl: Dachknoten D3 H01 0080
Seriové číslo: 00000313500018
Kódování: 0068948
VCID: 1D37BD4DC41687F6901-8048
1 nalezena chyba:
01299 - diagnosticky interfejs pro datovy BUS (J135)
004 - zadny signal / komunikace - Sporadická
info o závadě:
Stav závad: 00100100
Priorita závad: 0
Frekvence závad: 1
Počítadlo resetů: 78
Indikace času: 0
Datum: 2003.10.08
Čas: 00:36:00
Adresa 42: El. dveří řidiče Labely: 4E1-910-802-42.lbl
Řídící jednotka SW: 4E1 910 802 HW: 4E1 959 801
Díl: Türsteuer.FS BRM004 0080
Kódování: 0027425
Adresa 46: Komfort systém Labely: 4E0-910-289.lbl
Řídící jednotka SW: 4E0 910 289 A HW: 4E0 907 289
Díl: Komfortgeraet H03 0030
Revize: 00300003 Seriové číslo: W040305200198
Kódování: 0000576
VCID: 275B9FA5964A5D26FAD-8072
Adresa 47: Audio soustava Labely: 4E0-910-223.lbl
Řídící jednotka SW: 4E0 910 223 P HW: 4E0 035 223 A
Díl: DSP-Amp.-High H13 0460
Revize: PROD_01 Seriové číslo: 00000000057294
Kódování: 0000016
2 závad nalezeno.
000 - -
info o závadě:
Stav závad: 01100000
Priorita závad: 7
Frekvence závad: 254
Kilometry: 179184 km
Indikace času: 0
Datum: 2014.03.23
Čas: 19:13:37
02084 - chraneny dil
info o závadě:
Stav závad: 01100101
Priorita závad: 6
Frekvence závad: 1
Počítadlo resetů: 6
Kilometry: 130200 km
Indikace času: 0
Datum: 2010.08.05
Čas: 20:52:40
Adresa 4F: Centrální elektrika II Labely: nevybrány
Řídící jednotka SW: 4E0 910 280 HW: 4E0 907 280 A
Díl: ILM Beifahrer H06 0060
Revize: Seriové číslo: 00000000015174
Kódování: 0010111
VCID: DDB77D4D049647F6501-8088
1 nalezena chyba:
02258 - otevirani dveri
info o závadě:
Stav závad: 01100100
Priorita závad: 3
Frekvence závad: 1
Indikace času: 0
Datum: 2003.10.08
Čas: 00:35:00
Adresa 52: El. PP dveří Labely: 4E1-910-802-52.lbl
Řídící jednotka SW: 4E1 910 802 HW: 4E1 959 802
Díl: Türsteuer.BF BRM004 0080
Kódování: 0027425
Adresa 53: Parkovací brzda Labely: User\4E0-910-801.clb
Řídící jednotka SW: 4E0 910 801 C HW: 4E0 907 801 A
Díl: EPB A32C0220 H02 0220
Revize: A32C0220
Kódování: 0000531
Dílna #: WSC 27162 401 83030
VCID: 1F4B8745CE1A95E682D-804A
Adresa 55: Reg.sklonu Xenonů Labely: 4E0-910-357.lbl
Řídící jednotka SW: 4E0 910 357 HW: 4E0 907 357
Díl: Pre-AFS H01 0030
Kódování: 0000002
VCID: E2CD4EB13DE8780E6D3-80B7
Adresa 56: Rádio Labely: 4E0-910-541.lbl
Řídící jednotka SW: 4E0 910 541 Q HW: 4E0 035 541
Díl: TUNER EU/US/RDW H41 0620
Revize: 00000000 Seriové číslo: 304EA037526003
Kódování: 0000001
VCID: 2E556A81B9B00C6E39B-807B
Adresa 61: Regulace baterie Labely: 4E0-910-181.lbl
Řídící jednotka SW: 4E0 910 181 HW: 4E0 915 181
Díl: ENERGIEMANAGER H02 0160
Revize: 00000000 Seriové číslo: 00000000008068
Subsystém 1 - Řídící jednotka: 000 915 105 AK
Díl: von VA0 9856321473
Kódování: 303030393135313035414B56413039383536333231343733
Adresa 62: El.LZ dveří Labely: 4E0-910-802.lbl
Řídící jednotka SW: 4E0 910 802 HW: 4E0 959 801 A
Díl: Türsteuer.HL BRM004 0080
Kódování: 0028449
1 nalezena chyba:
02126 - tlacitko centralniho zamykani: vnejsi klika dveri
info o závadě:
Stav závad: 01101000
Priorita závad: 3
Frekvence závad: 1
Indikace času: 0
Datum: 2003.10.08
Čas: 00:35:46
Adresa 65: Hlídání tlaku v pneu Labely: 4E0-910-273.lbl
Řídící jednotka SW: 4E0 910 273 HW: 4E0 907 273
Díl: Reifendruck 2 H01 0210
Kódování: 0212127
VCID: DFCB47450E9A55E642D-808A
Adresa 67: Řízení řeči Labely: 4E0-910-75x-67.lbl
Řídící jednotka SW: 4E0 910 753 F HW: 4E0 035 753
Díl: SDS 3500 DE H42 0380
Revize: 00000000 Seriové číslo: 00000305020008
Dílna #: WSC 12336 024 394758
VCID: 28599C999B54525EF37-807D
Adresa 72: El.PZ dveří Labely: 4E0-910-802.lbl
Řídící jednotka SW: 4E0 910 802 HW: 4E0 959 802 A
Díl: Türsteuer.HR BRM004 0080
Kódování: 0028449
Adresa 76: Park. pomocník Labely: 4E0-910-283.lbl
Řídící jednotka SW: 4E0 910 283 HW: 4E0 919 283 A
Díl: Parkhilfe 8-Kan H07 0030
Kódování: 0101008
VCID: E0C944B933E46A1E7B7-80B5
Adresa 77: Telefon Labely: 4E0-910-333.lbl
Řídící jednotka SW: 4E0 910 333 F HW: 4E0 862 333 C
Díl: TELEFONMODUL EU 0770
Revize: 00000006 Seriové číslo: T2AUDX0505J8LX
Kódování: 0000004
Konec -------------------------------------------------------------------
Old 07-24-2014, 01:43 PM
  #17
mishar's Avatar
Nice! Though I understand few words I can only guess the real meaning. I believe you don't want guesses.
Old 07-25-2014, 03:44 AM
  #18
Knightey-'s Avatar
I am sorry, I forget it.
I made a translation for you and I deleted units without mistakes.
Thursday,24,July,2014,19:57:58:42825
Verze dat: 20131014
Kilometers: 182250km Číslo zakázky:: A8D3_newABS
Model: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1D 1E 25 34 36 37 38 42
VIN: WAUZZZ4E04N003347 Kilometers: 182250km
03-Brake Electronics -- Status: Broken 0010
05-Access/Start Authorization -- Status: OK 0000
06-Seat Adjustment (Passenger) -- Status: Broken 0010
09-Central electronics -- Status: Broken 0010
34-Level Control -- Status: Broken 0010
36-Seat Adjustment (Driver) -- Status: Broken 0010
38-Roof Electronics Driver -- Status: Broken 0010
47-Sound System -- Status: Broken 0010
4F-Central electronics II -- Status: Broken 0010
62-Door Electronics Rear Left -- Status: Broken 0010
Address 03: Brake Electronics Labels: User\4E0-910-517.clb
Control Unit SW: 4E0 910 517 B HW: 4E0 614 517 BC
Coding: 0000000
2 found errors.
01044 – Control Moduler Incorrectly Coded
000 - -
00778 – Steering Angle Sensor (G85)
005 – No or Incorrect Basic Setting / Adaptation
Address 05: Access/Start Authorization Labels: 4E0-910-131.lbl
Control Unit SW: 4E0 910 131 HW: 4E0 909 131 C
Revision: 01203602 Serial number: AUX3Z0C4314972
Coding: 0409600
Subsystém 1 - Control Unit: XXXXXXXXXXX
Díl: ELV XXXX
1 found error:
00181 – Access/Start Authoarization Antenna (in Rear Bumper) (R136)
011 – Open Curcuit
Info about fault:
Status fault: 01101011
Priorita fault: 4
Frekvence fault: 0
Reset Counter: 38
Kilometers: 182256 km
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:40:10
Address 06: Seat Adjustment (Passenger) S Labels: nevybrány
Control Unit SW: 4E0 910 760 C HW: 4E0 959 760
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
1 found error:
01721 – Sensor for Rear-Vertical Adjustment, Passenger Seat (G280)
Info about fault:
Status fault: 01101010
Priorita fault: 4
Frekvence fault: 7
Reset Counter: 38
Kilometers: 0 km
Indikace Timeu: 0
Date: 2003.01.01
Time: 00:00:00
Address 08: Climatornic/Heating Labels: nevybrány
Control Unit SW: 4E0 910 043 HW: 4E0 820 043 A
Revision: 00000017 Serial number: 00000000017243
Coding: 0004201
1 found error:
01206 - Signal for Duration of Ignition Off Time
014 - defekt
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0409600
Díl: ELV XXXX
1 found error:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
Info about fault:
Priorita fault: 4
Frekvence fault: 0
Reset Counter: 38
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:40:10
Address 34: Level Control Labels: 4E0-910-553.lbl
Control Unit SW: 4E0 910 553 F HW: 4E0 907 553 E
Coding: 0011110
2 found errors.
01575 – Control Switches Off
000 - -
Info about fault:
Status fault: 11100000
Priorita fault: 4
Frekvence fault: 1
Reset Counter: 38
Kilometers: 182258 km
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:36:44
008 – Implausible Signal
Info about fault:
Status fault: 11101000
Priorita fault: 3
Frekvence fault: 1
Reset Counter: 38
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:36:44
Address 36: Seat Adjustment (Driver) Labels: nevybrány
Coding: 4063342
1 found error:
01445 - Sensor for Driver Seat Fore/Aft (G227)
010 – Open Circuit / Short Circuit
Info about fault:
Priorita fault: 4
Frekvence fault: 1
Reset Counter: 38
Kilometers: 119080 km
Indikace Timeu: 0
Date: 2010.03.12
Time: 02:39:51
Address 38: Roof Electronics Driver Labels: 4E0-910-135.lbl
Control Unit SW: 4E0 910 135 A HW: 4E0 907 135 A
Serial number: 00000313500018
Coding: 0068948
1 found error:
01299 - Diagnostic Interface for Data Bus (J135)
004 - No Signal / No Communication - Sporadic
Info about fault:
Status fault: 00100100
Priorita fault: 0
Frekvence fault: 1
Reset Counter: 78
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:36:00
Address 47: Sound System Labels: 4E0-910-223.lbl
Control Unit SW: 4E0 910 223 P HW: 4E0 035 223 A
Revision: PROD_01 Serial number: 00000000057294
Coding: 0000016
2 found errors.
01044 - Control Module Incorrectly Coded
000 - -
Info about fault:
Status fault: 01100000
Priorita fault: 7
Frekvence fault: 254
Reset Counter: 38
Kilometers: 179184 km
Indikace Timeu: 0
Date: 2014.03.23
Time: 19:13:37
02084 - Component Protection
005 - No or Incorrect Adjustment
Info about fault:
Status fault: 01100101
Priorita fault: 6
Frekvence fault: 1
Reset Counter: 6
Kilometers: 130200 km
Indikace Timeu: 0
Date: 2010.08.05
Time: 20:52:40
Address 4F: Central electronics II Labels: nevybrány
Control Unit SW: 4E0 910 280 HW: 4E0 907 280 A
Revision: Serial number: 00000000015174
Coding: 0010111
1 found error:
02258 – Door Opener Transmiter
004 – No signal / Communication
Info about fault:
Status fault: 01100100
Priorita fault: 3
Frekvence fault: 1
Reset Counter: 38
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:35:00
Address 62: Door Electronics Rear Left Labels: 4E0-910-802.lbl
Control Unit SW: 4E0 910 802 HW: 4E0 959 801 A
Coding: 0028449
1 found error:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Info about fault:
Status fault: 01101000
Priorita fault: 3
Frekvence fault: 1
Reset Counter: 38
Indikace Timeu: 0
Date: 2003.10.08
Time: 00:35:46
Old 07-25-2014, 08:12 AM
  #19
mishar's Avatar
Thanks. I think that problem is Steering Angle Sensor. Replacing is not that difficult but it has to be same as one you have.
Rest of faults can be addressed later.
Old 07-25-2014, 11:43 AM
  #20
Knightey-'s Avatar
Ah, really?
Do you think, that the broken abs unit destroyed this steering angle sensor? Is it possible?
I think, that this newer ABS unit can't communicate with this older steering angle sensor.
Becase you wrote me, that they have different plugs. So they must have different connection right?
Anyway, today I bought another ABS unit with same number which I owned in this car.
And for safe, I bought also new steering angle sensor for your advice.
Tomorrow I am going to test it. I will swap the steering angle sensor and try to code the newer unit, which I have in car. If I will not successfuly, them I am going to change ABS unit again, for older one.
Only one think, I am afraid of that I can destroy this steering angle sensor, if I will use it, with this newer ABS unit.
What do you think about it?
Or do you have any next advice for me for tomorrow?
Thanks for your help and time!
Quick Reply: ABS ESP Bosch 5.7 unit - can I replace?
