Sponsored by:
Sponsored by:
Air Suspension
Old 07-11-2018, 09:46 AM
Jose Arriaga Jr.'s Avatar
Default Air Suspension
As I was driving my front end went down and it was showing the orange car light and flashing the green down arrow light. I connected the Vag com and it read Front right level sensor 012- Electrical fault in circuit. I cleaned the connections to that sensor and still the same. Is it the sensor that went bad?
Old 07-11-2018, 10:13 AM
dan87951's Avatar
Did you inspect the cable sheathing and make sure it's not damaged? There could be a cut or break in the wire you're not aware of. I would inspect the cable very carefully before replacing the sensor.
Old 07-11-2018, 10:20 AM
I checked every wire I also checked the coltage and it is currently fine and I checked the mean blocks on vag com and it shows every other level height just fine except the right it is way off
Old 07-11-2018, 04:10 PM
ltooz_a6_a8_q7's Avatar
If you don't want to break anything more by using the VCDS, use a simple test in many posts about suspension. Yellow light and Green light. I did have one of the simple test to find the problem in my suspension problem posts. People with VCDS don't fix the suspension correctly.
Cheers,
Louis
chook89
Suspension Tuning Discussion
07-08-2015 09:06 PM
bredenoord
2.7T V6 Discussion
06-16-2006 05:09 PM
rasto
04-04-2005 02:11 PM
golddog
08-21-2001 06:13 PM
MichaelTT
10
07-09-2001 06:45 AM
Quick Reply: Air Suspension
