AMI Update
#51
The Transporter
I checked my version via the red update menus and found that indeed I already had the latest version. I bought the AMI from someone on this forum so I should've figured they'd have kept it up to date =D. Was able to pick up the songs on the USB thumb drive and play them just fine. Now I need to load up something with my music collection, stick it in the glove box, and be gravy.
Thanks
Thanks
#52
not to be too off topic -- but I've given up on changing my 2006 system because a $500 part is needed to expand the system (i've already bought the harness and even the audi bluetooth reciever that plugs into the $500 adapter. Instead, I went to walmart and got a $7 1/8" plug radio transmitter that seems to be just as good as most bluetooth qualities I've heard. It runs on AAA batteries that i've not had to change. THen I upgraded to the better quality cigarette lighter plug-in unit for the trunk (crutchfield) for about $38. I'm happy enough with them -- however if making a long trip and passing through a city with same broadcast you need to go into trunk to change frequency.
I would like a backup camera.
I would like to get the bluetooth music component for less than $500
but i've ran out of patience.
During a battery replacement to an AGM I somehow messed up my AMI. I forget how or why, but it did start 100% volume of highly distorted sound. There is a restore to factory default option in AMI and that did the trick. No issues since the restore to factory.
One complaint is the CRAP signal quality and high compression of music on the satellite xm songs. It's that way on every car. not worth more than $99 as an option. Its sad because they USED to have a low compression upgraded signal option that WAS hifi. not any more. the greed of the sat companies kicked in. what a Shame.
My best music comes from high quality CDs. it's awesome in the 06 era A8L. Some day I will upgrade to a bang-olufsen A8L, but right now I'm getting another 100K out of this magic car and loving it. Radio signal in Florida is pretty good, especially in Miami. we have HDradio on a newer passat TDI we picked up this summer and it's a hassle dealing with the HD2,HD3 channels -- another missed opportunity for most people for great music they dont know about.
#53
XCARLINK Doesn't Use AMI
https://www.ebay.co.uk/itm/Audi-2G-MMI-Fiber-Optic-MOST-Bluetooth-Streaming-Interface-Adapter-AUX-A6-A8-Q7/263973188352?hash=item3d76073300:g:axEAAOSwE8Vbthy U
#54
The Transporter
I might end up re-installing my CD player alongside the AMI so that I can get the kit that user 'bluewavestudio' is selling. He isn't 100% sure it works with AMI, but it shows up as CD #7 on the CD changer. I will just need the MOST splitter and whatnot so that I can have both installed, and then get his kit.
I have a feeling, however, that his kit would work with the aux item as a source if plugged in directly to AMI. I might buy the kit, try it with my AMI unit only, and if not I'll grab a splitter and install my CD changer and do that way. His kit is really nice from what it looks like.
#56
I presume you’re talking about trying to update your AMI with the USB stick? i suspect your AMI is alrady up-to-date if nothing happened. that was my experience when I tried the USB ...
Use the hidden red menu to check your code level
Julian
Julian
#58
As per the previous thread item; suggest you use the 'hidden red screen' option to check your current AMI level. The latest / final version is 4E0 035 785 F, which corresponds to AMI level 0850.
Julian
See Thread entry #40 for an expaianation of the Red Menu and how to access it!
https://www.audiworld.com/forums/a8-.../#post24986416
Julian
#60
Julian
Julian
