Anyone ever replace MMI interface?
#71
Yep component protection is active. Also says needs the adaptation.
OK do I use the heat gun trick - or dealer it? I tried the heat gun and pulled the chip already...
PS: My energy management or battery module is toast/not responding. Dang. Might have to trade this thing in for something more reliable like a Maserati Quattroporte crica 2007
Dont do it unless you know what you're doing. I would rather have used an in circuit programmer to copy it but as I didnt have one with small enough clips to get to the pins I swapped them. Using a heat gun for removal was good but I had to use a tiny solder iron and flux to get it back on. The heatgun wasnt good for putting it back on the pads. In my case I think it was because most of the solder came off with the old eeprom.
#72
Yeah i practiced - heat gun on high, removed several chips on the old board. Then removing the EPROM a little cap or ? and the video port literally exploded off the board. It was part of that video circuit.
I lost two diodes? near the EPROM.
My soldering iron and eyeballs are NOT up to this - FRIG!! I looked around to get some magnifiers this week nobody has them. I'm really lucky I didn't get hit in the eye with that component that blew off.
Tried to get the chip back on - I think it's fried. NOTHING works now. Replacing little microchips without proper tools = stupidity.
#73
hope this helps
#74
Thanks for the write -up it does help. I'm also (way back) electronics/ current systems engineer - but don't have PCB/small component etc capability, as I have CNC/machine shop now . This is my first go at surface mount. But the biggest problem I have is vision - seeing the details. Because I can't see for beans .... pulled a leg off the EPROM so that is that. End of madness.
Ordered another A8 MMI from EBAY and will try the dealer route.
#75
Is the leg off the new or old? Take the pictures so I can see. Send both boards to me, I can ask someone to do it nicely. Cheaper for the cost of shipping. Hold off on the new order. USPS flat rate box $7.20 x2 <$15.00.
Cheers,
Louis
Cheers,
Louis
#76
I ordered another module $100
#77
Wrapping up my saga, the dealer recoded the used module from eBAY cost of $300
Notes - I had installed the used module and everything works, until you start the car then from there its just stuck on audio MUTE
The dealer had to pull the dash board again and pull the module, bench it and re-install. Apparently could not remove comp protect while in the car
#78
How would you remove CP if it was out of the car
#79
I've heard of the dealer removing CP before, but no one has mentioned removing it from the car. My guess is that they just told you that to justify the cost. I don't see why they wouldn't be able to plug into the OBD port and do it like they do with everything else software related, MMI updating excluded.
#80
Well I can got back in there to see if that is the case. Because I left the one plug retainer down and used the wrong screw in one spot. And I left out the plastic duct (which is a PIA)
Crazy thing they let the car out of the dealership with a hard BRAKE (!) fault due to no brake fluid !!
