Sponsored by:
Sponsored by:
Anyone use a scissor lift or 2 post lift at home?
Old 12-31-2013, 04:52 AM
greginfinity's Avatar
Default Anyone use a scissor lift or 2 post lift at home?
I might purchase something to help in the minor repairs that I do to my cars. I am getting too old to crawl around and break my back, so I have been looking into both types of lifts. The scissor lift seems the least obtrusive to put in a garage, but the 2 post has its advantages. Just looking for specific thoughts from A8 owners!
Things I would likely work on:
-Oil changes
-Suspension issues
-Brakes
-Transmission fluid changes
-Exhaust
-Maybe timing belt
Old 12-31-2013, 07:05 AM
03_AR_CO's Avatar
-Oil changes
-Suspension issues
-Brakes
-Exhaust
-Maybe timing belt
For all of the very same reasons, age and consuming valuable space in my garage I have been eyeballing the scissor type. I will be interested to see other responses.
Happy New Year everyone.
Old 12-31-2013, 07:56 AM
Vondera's Avatar
We have an asymmetric two post lift made by Forward. It works great because the lift and arms are always out of the way for anything from oil change to brakes to exhaust. They're typically over $3000, but we bought it used from a dealer that was going out business for less than $1000.
Once you use one, you'll wonder how you worked without it. If you're not in a hurry, keep an eye out for auto shop auctions. There are cheap ones out there, but this is one tool I would not skimp on.
The only reason I see to buy a four post would be if you plan to use it to expand your garage, that is to keep a car in the air above another parked car. I've seen it done, but obviously not recommended.
Old 12-31-2013, 09:51 AM
MP4.2+6.0's Avatar
Default I'm still...
on a combo of floor jack and ramps. I have a slope driveway so when I need to get it up but flat (like tranny fluid check) I put it nose down slope on the ramps and get it back to essentially flat--using a level on roof at known point to check. Harder w/ the A8 than my old A6 as a BTW since cheap level magnet doesn't stick to aluminum roof!. For brake jobs and such, I just do a side at a time in front with the floor jack--and jackstand for safety. In the back I can get it up by going under the rear diff center support to do both at once.
Yes, crawling under it gets old at my advancing age, but I don't think I want the tripping problem w/ something bolted to the floor, unless I went to the trouble of some kind of removable bolt stuff with big concrete anchors. I don't have the ceiling headroom for the more substantial up in the air rack type stuff, let alone want to spend the $$.
Old 12-31-2013, 11:02 AM
gaspasser19's Avatar
I look forward to building a "final resting place" in about 3 years. When I do, the plan is to install a 2-post like yours.
However, I have to disagree with your statement that storing additional cars on a four-post is not recommended. They are specifically designed to serve as platforms for storage.
Old 12-31-2013, 01:55 PM
Vondera's Avatar
Oh, I didn't mean they couldn't do it. In fact even the two post has adequate locks. I was thinking that I would not want to park my A8 under another vehicle (for fear of leaks, etc.)
Old 01-01-2014, 07:01 AM
Gary Knox's Avatar
I agree with Vondera's post regarding the 'joy' of having a 2 post lift. It does require a high ceiling, however.
I built a detached 'hobby garage' about 6 years ago, and use it frequently for the servicing/maintaining of our cars. The ceiling is 10'6" and gives me plenty of clearance for the cars and me working under them (but I'm only 5'7"). The header of the lift goes above the ceiling into a box area above it. This arrangement is fine for full size automobiles, but probably would not be satisfactory for SUV's, pickemup trucks, etc. 12' ceilings might be better for those vehicles.
Once you put the lift in you will NEVER regret it, as long as you enjoy working on your cars.
Gary-
Old 01-01-2014, 03:02 PM
mishar's Avatar
Size:  127.6 KBName:  001-2_zpsbf26251d.jpg
Old 01-01-2014, 04:07 PM
Fez2013's Avatar
That looks amazing, got some more pictures of it?
Old 01-01-2014, 09:34 PM
mishar's Avatar
It's not as handy as hoist but not es expensive either.
I like this one:
<iframe width="560" height="315" src="//www.youtube.com/embed/QSUAXQOoXuY" frameborder="0" allowfullscreen></iframe>
Quick Reply: Anyone use a scissor lift or 2 post lift at home?
