audi A8 w12 dyno results
Besides the low volume, another of the things that makes the W12 less moddable. Would be interesting if the claims are legit and they have actual dyno runs before and after's to support it.
The only W12 file they have on hand ready to flash today is for the phaeton W12 ECU ID 07C906018C. You can recover the ECU ID from vagcom to see if this is the computer code you have. All that means is you would not have the tune back the same day. It means that what ever dealer you go to for a unitronic tune will have to copy the file from your computer and send it off to their head quarters so they can work their wizardry on it and send it back.
I do have a before dyno and I may take another crack at this in a little while to see how much power can be gained.
stage 1+ is generally a 93oct tune that is about aggressive as you can get without any hardware changes (stock exhaust, turbo intercoolers, ect)
stage 2 usually requires some hardware changes such as downpipe or full exhaust.
In my example I essentially requested a stage 2 file to be used with a full cat delete and so emissions remapping as well as removing the massive delay when applying and removing throttle inputs. It is not a easy modification when working with this car. I am sure they could do it if I gave them some more time to handle it.
MTM had a W12 program so presumably they had it sorted, and the dealers must too, more so for the higher volume similar twinned V10 in the D3 S8 and C6 S6 if I remember right.
If all they have is a Phaeton W12 program, I would definitely run that down more for the underlying specs and applicability. IIRC, U.S. W12 Phaeton was 420HP/408 ft lbs. (A8 = 450/428) and I thought it had the older 5 speed tranny. Thus detuned off the Audi w/ the same 6.0L displacement, plus heavier to boot. Not sure where they went with the specs in Europe after they pulled the plug on it in the U.S.
I can't speak on power gains or anything about the tunes on the W12. I just looked up to see what files they had available for me to write and the W12 phaeton is there on hand. I do know that I want more power and I want to hear a exhaust note, and at some point I will pursue this further to get a tune. If that means taking the car in person to their HQ for dyno time then that is what it is.
Second, look at what Audi itself did on the D4 to up the power on the W12, still within NA confines. It did not just massage the existing set up with a re tune, hotter cams, bigger air boxes, a bit higher compression or more exhaust. It had to go into the engine itself and both increase the displacement and rework the heads to accept FSI; with the FSI it could then bump the compression yet further.
Third, there is no known higher HP version of this motor in NA form (put aside turbo'ed Bentleys), and other respected tuners like MTM don't make HP claims for their (limiter removing) chip http://www.mtm-online.de/en/Audi/A8-...T=mw12450450qx, or for their exhaust for that matter.
Finally, I tried to say this gently on the prior post, but I think indirectly you may have touched on where your point is true, but then reveals on the A8 why you may not find anything: on "lesser" models or ones further down the price curve, Audi/VW may indeed detune it to keep prestige differentiation to the more expensive model. Thus the 4.2 from the A6 to the A8 as an example where there are known different states of manufacturer tune. Owning an A6 4.2, I can see how the air box is restrictive (and was opened up some on the S6, the S8 and the D3 gen of A8's. I can also see the throttle body is clearly sized down relative to the manifold machining, and I can guess the A8 one isn't. Other times they will do it in the exhaust a bit too. Moving to the D3 A8 W12, I mentioned the Phaeton down tuning on what is still a 6.0 motor and almost certainly the same heads, pistons, and manifolds. But, a quick tweak to the ECU's or maybe some smaller throttle bodies or MAF tubes and presto, down 30HP. If you look at the specs you had for the chip and apply it to the VW Phaeton W12 specs, it's just getting back to around the Audi W12. Thus, you can get back from the Phaeton to the D3 if you know where the tweaks were, but not really from the max state of (legal/emissions) tune where Audi seems to have left the D3.
If you solve it and can get the dyno's for it great. But since it's NA with generous manifolding on both ends, seems unlikely.
Second, be sure you understand the internals of the W12. The con rods are siamesed on the crankshaft journals in pairs of two cylinders. BUT, those journals are actually offset one to the other, and there is no main bearing or cap in between. They have to do that because of the nature of the W heads and diagonal staggering of the bores on each side. That means there is a stress point on the crank at each of those offset journal areas. And in turn, that is specifically why a W12 can't and shouldn't be tuned for higher RPMs than its fairly leisurely redline. Yeah, it's forged and has really robust bearing girdles/lower crankcase assembly and all that, but that split point can't change in a W12 set up. Audi documents that in the W12 SSP if you want to read further. Meanwhile, if I were opening up a motor to make it breath better, I would likely be pushing the revs too, but that just doesn't work here.
Third, think about the S8. It's 5.2L instead of 6.0, but it likely breathes better on the intake side anyway without the compromise of the fairly byzantine gas flows of the W12 heads generally. That is a much higher rev motor than the W12, but I'm not aware they bumped the exhaust there either.
Finally, not a fan of desmogging--plus CA has checks every 2 years anyway--and the forward pre-cats are there (a lot of them) to meet smog regs since circa 2004; actually why the old C5 RS6 was a 2003 MY only.
